My good friend, who has also been a really good customer over the years finally let me go all out on his trunk, the way I felt would work best for some good slappage
Went thru 12"s 15s, 18"s almost ran 6-10s, but told him, he needs to get that rear deck torn out, so he did
1998+ Buick Lesabre's are no joke getting really loud, this is my 3rd serious build on them, now I learned the way ....
tear out the rear deck, and seal off the trunk completely- still have a few steps to go, but for now, got the majority of it down
I built the subs from scratch, needed to build something he will be happy with, and take his abuse. Think I finally got it.
The amps are 1-SAZ1500D for now, will be a second really soon, and run them at half ohm each, or 1 ohm strapped
Box is 7cf tuned to 40 hz with a guide to direct the bass right in the cabin
The guide is adjustable to compensate for pressure, and tuning, the port will also be tuned down after full break in of the subs
The suspension is extremely tight, so tight Zmax is 40ohms, while most subs are 80+ohms
So what that means is they will see higher power for a wider bandwidth, and a more constant actual rms rating from the amp
Anyways, Iam beat, heres the pics from tonite, it still needs to be carpeted, and threaded rod to go thru the spare tire well, and bolt on the guide to the box
So dont talk shit, its only 3/4 the way done
With 1 amp alone, I hear with the EAR-O-Meter a easy 145+, so I cant wait for the second amp, and to get this thing more secure, and more batteries
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
CC- Your next, I'am free for your build now, sorry for laggin
damn man, its lookin good. i cant believe you cut out the entire rear deck :shok:
Alpine 9886
Polk Audio 6.5 Component db series
Elemental Designs nine.4
JL Audio 1000/1
DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz
Clarion EQS746
Stinger Voltage Meter
Optima Yellow Top (Front)
XS Power 1200 (Rear)
All KnuKonceptz Wiring
that rear deck had it comming
completely deserved it.. lol
Love the build man. Have you thought about using the spare tire well for air space to allow more room in the trunk for batteries and amp placements. Something like this!
Posted Image
Dont mind the glass work this was just the first couple of layers, think I ended with about 8-10 total.
Posted Image
Posted Image
This box has just under 8 cubes and after displacement we have 3.78 per 15, and only used half the wheel well. Could easily get 1-2 more. We have reached some high numbers and have not sealed it off yet.
You guys have more pictures? I am tuned into this build for sure..
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
yeah, Iam going to talk him in to smaller batteries, because those yellow tops do not fit down there, that was my first option for him
But right now, the batts will go on each side of the box
before this, it was a spare tire well, fiberglassed for a 18" I built him, but the glassing started to break away, so had to do something bigger
Cool deal, need more pictures...
You got pics of the 18 box?
How did you go about caculating the cubic feet of the wheel well??
Random vids of the Avalanche My link
Team Bass-Hz
How did you about caculating the cubic feet of the wheel well??
we tried to make the wheel well as square when calculating the volume. We measured side to side and front to back and bottom to top and that got us the total of the wheel well. And of course we had to guess a little on the round parts.. that why I stated it was just under 8 cubes. Not an exact science by no means but I would say we are very close.
I am sure there are people on here that can get the exact volume but I just needed close.
How did you get the volume Forevrbumpn?
yeah, it was a really simple box, just a flat false floor
This was it stripped down before the 18" ( was dual 15"s)
Posted Image
Posted Image
The 15"s from before ^
Posted Image
Went to the 18" ^
Posted Image
I think this one with the 18" I just modified the port to be to small. I just downsized the port from 3" wide to 2.25" wide and was 5.5cf I believe, somewhere around there
edit:
more pictures next time he comes thru, he drives here from the SF Bay Area, so its a long trip- 100miles each way
next time will be mainly just sealing off, sound dampening, box bolt down, and fine tuning the width of the open area in the guide.
Might also chop about 2" off the back of the box to make things easier
Nice build Sod, have final build , or a build log?
