AKaylor09 Posted September 22, 2009 Report Posted September 22, 2009 Im plan on putting in a t40001bd with two fi btl 15's in my car but am not sure of what electrial upgrades im going to need. I have already done the big 3 with 1/0 wire under the hood. So what size alternator am i going to need, do i need extra batteries, or do i need any caps. I want to make sure that my volts aren't dropping so the amp wont shut off and i dont want my headlights to dim either. Can anybody help?
wL<3bass Posted September 22, 2009 Report Posted September 22, 2009 For that amp I would recommend atleast a 200amp alt (or the biggest you can get for your car) and 2 hc2400 or d3100 and a good under hood battery. You may be able to get away with less....but myself I prefer to have overkill... As far as headlights dimming they are gonna dim regardless of voltage drop.....halogen bulbs are an unregulated (the more voltage you feed them the brighter they are) just how much they dim is dependant on voltage drop....get some HIDs to save your headlights from dimming. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
CASZ71 Posted September 22, 2009 Report Posted September 22, 2009 What do u drive 2000 GMC sierra 1500 ext cab KMC XD Spy series rims Front doors Fosgate punch 6 1/2's stock tweets Rear doors Fosgate power 4x6's Probox 10 and box under rear seat Rockford fosgate R-500 Prime series amp (537 rms) 4 gauge wiring
AKaylor09 Posted September 22, 2009 Author Report Posted September 22, 2009 would i have my power wire run from my battery under the hood to the two batteries in the trunck and run them in parallel and then what battery would i hook my amp up to? 89 bick lesebre
trappin859 Posted September 23, 2009 Report Posted September 23, 2009 would i have my power wire run from my battery under the hood to the two batteries in the trunck and run them in parallel and then what battery would i hook my amp up to?89 bick lesebre Front batt-----(fuse)--------------(fuse)-----1st rear batt-----2nd rear batt---(fuse)---Amp You will also want to ground all of the batteries and the amp. The easiest way is to ground each battery seperatly. Current '09 mazda3 4dr clarion hu 2x 10 fi X subs(looking to upgrade) amp(looking) Alpine type-r comps in front type-r coaxials in rear
