Boyd Heaton Posted September 25, 2009 Report Share Posted September 25, 2009 plan on using knu 1/0. I am in the same boat...A stand alone 250 Rhino and 4 d3100's for 2 atomic 5k's with 3 runs of 1/0...This alt will only feed the sub amps...We shall see I guess Quote Dual DC Power 270XP's One XS Power S3400 Four XS Power D3100's Soundigital 12kd Four DC Audio 15XL's Atomic 504 Kicker Mid's and High's One SoftTop Jeep Wrangler TNESPL-152.5 DB DRAG-153.2 ON THE ROAD TO "55" Link to comment Share on other sites More sharing options...
troy Posted September 25, 2009 Author Report Share Posted September 25, 2009 so your gonna run duals?? Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs Link to comment Share on other sites More sharing options...
tejcurrent Posted September 25, 2009 Report Share Posted September 25, 2009 I am in the same boat...A stand alone 250 Rhino and 4 d3100's for 2 atomic 5k's with 3 runs of 1/0...This alt will only feed the sub amps...We shall see I guess I would do 2 alts, they are the source of power for the batts, and depending on the vehicle easier to fit than a huge battery bank. Quote tejcurrent XS Power T3 Link to comment Share on other sites More sharing options...
troy Posted September 25, 2009 Author Report Share Posted September 25, 2009 s10 truck with a 4.3. i have a huge bed but im pretty cramped under the hood. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs Link to comment Share on other sites More sharing options...
Derrick824 Posted September 25, 2009 Report Share Posted September 25, 2009 I recommend 4 batts to be safe but you will be alright with 3. Make sure to get the biggest batt you can fit under the hood too. Quote Link to comment Share on other sites More sharing options...
troy Posted September 25, 2009 Author Report Share Posted September 25, 2009 I recommend 4 batts to be safe but you will be alright with 3. Make sure to get the biggest batt you can fit under the hood too. what about alts? would i be ok with the single 250 and 4 bats? Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs Link to comment Share on other sites More sharing options...
Boyd Heaton Posted September 25, 2009 Report Share Posted September 25, 2009 so your gonna run duals??Yes...I have a 200amp Mean Green in the stock location.Which will run the Jeep and highs amps...And the Rhino with adjustable voltage to feed the 3100's for the 2 atomic 5k's Quote Dual DC Power 270XP's One XS Power S3400 Four XS Power D3100's Soundigital 12kd Four DC Audio 15XL's Atomic 504 Kicker Mid's and High's One SoftTop Jeep Wrangler TNESPL-152.5 DB DRAG-153.2 ON THE ROAD TO "55" Link to comment Share on other sites More sharing options...
