2 Kole Audio 5500 watt amps & 2 12 Alphasonik Mayhem
Kole Audio 5500 watt amp specs:
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 watts x 1 chan.
Regulated PWM Power Supply
Wired remote bass level control included.
LED power indicators
Bass Boost: 0-18 dB at 45 Hz
Midnight blue anodized finish with silver end caps
High-speed digital circuitry
Three-way protection circuitry (short, thermal and overload)
Bridged synchronization (strap amps together for double power!)
Pre-amp outputs
1800 Phase switch
Variable low-pass filter (40-200 Hz, 12 dB/octave)
Variable subsonic filter (12 dB at 20-50 Hz)
Frequency response: 15-150 Hz
Low Level Inputs: 200mV-6V
Dimensions: 20-1/2L x 10W x 2-1/4H
1/0-gauge power and ground wiring is required for installation.
Alphasonik PSW912 specs:
Sensitivity: 95 dB
RMS Power Range : 2200 Watts
Impedance: Dual 2 Ohm
Dual Ohm Subwoofer
Cast Aluminum Machine Cut Alpha Basket
Motor Assembly Heat Sink
Ultra Light 2-Layer Carbon Fiber,
Kevlar Cone with Aluminum Dust Cap
TLTF J-Surround
Flat Progressive Rate Nomex Damper with Spiral-Woven Leads
8-Gauge Lug-Lock Input & Output Terminals
Rated at 2200 Watts RMS
93dB Efficiency
Frequency Response of 45Hz to 900Hz
200 oz. Triple-Stacked Magnet
Dual 2-ohm 3" Voice Coils
what is the point of this thread.
are you just sharing specs on what you have or trying to sell these? :unknw:
oh....ok. now i get it. lol.
how much are you willing to spend on this system? i think we can get you some better equipment for the money you would spend on that stuff.
Guest Cobrastang98
^^^ Would have helped out your cause to possibly mention that in the first post.
But I wouldn't get those amps or subs... Better products can be bought for cheaper without a doubt. What were you planning on spending on this??
Im also looking at buying a kole 5500 amp. And an orion HCCA sub. Does anyone else have this amp. How do you like it?
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
damn man. almost identical to my post. but i beat you by a couple seconds. :good:
  • Who's Online   0 Members, 0 Anonymous, 1429 Guests (See full list)
