how much port area for 2 DD 95Z 18's
Ok here goes. I was going to do a blow thru in my truck with three 95z 15's then I realized that 2 18's had almost the same surface area as 3 15's. So last week I sent my 2 15's back to DD to get upgraded and reconed to 18's. I wan't to have the box built before the subs come back but I'm conserened on how much port area I should run. DD calls for 6.5ft3 per woofer and 104 sq inches of port. I will be running the subs in around 10ft3 box so my question is should I still run the 208 sq inches of port DD recomends for 2 of these subs or should I run less port area because box volume is is smaller? Any advise will be appreciated wiether its for the amount of port area or the amount of volume for the subs. OHHH I almost forgot I plan on tuning the port to lower 30's. Thanks in advance everyone.
Heres the specs DD has on the website for the 95Z woffers I dont know if this helps but I'll post it anyway
SPECIFICATIONS
Series Z95
Voice Coil Diameter 3"
Magnet Weight < the Z
Power Handling RMS 2000
Suspension 80mm
Nominal Impedance .5 - 4.0 Ohm
DC Resistance .5 - 3.6 Ohm
Model Z9510 Z9512 Z9515 Z9518
Rec Box (cubic ft) 2 3 4.75 6.5
Port Area (sq in) 32 48 76 104
Port Length (inches) 22 21 20 19
Woofer Diameter 10" 12" 15" 18"
Free Air Resonance
Qts
Qes
Qms
Vas
Sensitivity
Shipping Weight
Edited by convectedfelon
Under construction
soon to be:
2 DD Z9518's
8 lunar L1500's (500rms each)
Secondskin Dampner pro
250a Mechman rhino alt
4 runs of 2/0 (installed)
4 batteries (installed)
6-5 1/4's, 2-6 1/2's, 2-4in all ma audio (installed)
Do you wants to do pencils and papers or box calculator to get the cuts?
I've been using a box calculator so far for all my calculations.
Under construction
soon to be:
2 DD Z9518's
If you're gonna cut down the box size, then you're gonna want to cut down the port area also. What kind of power are u gonna be running per woofer??
Well the amps are going to be 8 Lunar L1500's there rated at 500 watts rms a peice at 1 ohm on 12 volts, but we bench tested them at .5 ohms and at 14.7 volts(which is how I will be running them) and they each put out around 1100 watts. so I would say around 4k to each sub
Under construction
soon to be:
2 DD Z9518's
  • Who's Online   1 Member, 1 Anonymous, 438 Guests (See full list)
