all i could think of its a BAD ground..
maybe theres a loose ground in the hood. or something thats causing that.
i had the same problem for my 96 intrepid..only thing that was a BAD BAD ground..
check all the wiring in the car bro..or do the BIG III..that should help you out..
correct me if im wrong
I did a semi big III, It has 4 gauge stock and I added some more 4 gauge just until I can get some 1/0.
2 Infinity Reference 1252w 12s
4.2 cubic foot box tuned to 28hz
Sub amp: 1 Profile AP1200
Speaker amp: 1 Sony Xplod XM-504z
Kenwood eXcelon KDC-X492
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
f05112e8-c6ca-4f78-9a8d-47be99303c8b_zps
Diamonds are forever, but 9's end that shit fast....
I got my first 200amp form Excessive amperate, it worked great while i had it then i sold it on one of the forums when times got rough.
now i have a DC Power 200+amps one on the way
have you checked all your grounding on the engine and everything, try a big 3 on it maybe it will help some of these accords have been through shit and back so the facotry grounding straps are next to done on them.
how many batt's are you running??
maybe its time for a new one..
K thanks James. I did see that the factory ground is horrible. It looks corrodide as hell and has like half of the casing or rubber w/e you wanna call it gone from the wire so im going to fix that asap. ( the ground at the trany)
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
Im running just a stock wet cell up front.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
try checking all the grounds in the engine and if nothing changes add a new batt
or replace it.
or replace it.
Thanks, will do.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
