fosgate daisy chaining
troy
say i get 2 t2500s and i daisy chain the amps. i only have to mess with the settings and gains on the first amp correct??? also the bass knob on the first amp will also control the first on correct???
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Yep the second amp will go off the settings the first one is set at.
¿ǝɯɐƃ ǝɥʇ
but when running more than one kind of amp say a mids and highs amp you would have to run a different set of rcas correct???
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
correct...
and i also had a question about strapping these amps... i was thinking about getting a few, and was wondering if i needed multiple remote leads? ive watched steves build, but didnt catch that particular part, if anyone knows, thanks
Alpine CDA-9886Hertz Mille 3 ways active
Hertz SPL Show 8's
2 Audison Voce Quattro's2 DC Audio M2 Level 5 12'sDC Audio 12.0KKnuKonceptz Wiring4 XS Power D3100'sDC Power 390XPSecond Skin Damplifier Pro and Dynamat Xtreme
yea im pretty sure you would still need more remote leads from a relay. just do one ot the relay then as many as you from the relay
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
correct...
I believe he had sorta a line booster, he had 1 imput from the Deck, then it had like alot of outputs to go to the amps.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 683 Guests (See full list)
