unknown123 Posted September 30, 2009 Report Posted September 30, 2009 hi people!Im just wondering if a pioneer TS-W308D4 would work good on a MTX 1-Channel Car Amplifier (TN250/1) wired to 2 ohm.Also in a sealed 1.72 cubic foot enclosure(it has the sub displacement in there) will this setup work good and have good bass?
everfr3shh Posted October 1, 2009 Report Posted October 1, 2009 hi people!Im just wondering if a pioneer TS-W308D4 would work good on a MTX 1-Channel Car Amplifier (TN250/1) wired to 2 ohm.Also in a sealed 1.72 cubic foot enclosure(it has the sub displacement in there)will this setup work good and have good bass? Well i see the sub rated for 400 rms to 1400rms, and the amp is only 200 Watts RMS x 1 Channel at 2 Ohms id look for a different amp imo, what kinda budget do you have?
Guest Cobrastang98 Posted October 1, 2009 Report Posted October 1, 2009 Well i see the sub rated for 400 rms to 1400rms, and the amp is only 200 Watts RMS x 1 Channel at 2 Ohms id look for a different amp imo, what kinda budget do you have? Well the sub is actually rated for just 400rms, not 400-1400... 1400 is just what they rated the peak to be. But i do have to agree, i would find an amp that does a lil more power than the one the OP posted. If that is the only one he has, then i suggest to build an enclosure that will help increase the efficiency of the sub.
unknown123 Posted October 1, 2009 Author Report Posted October 1, 2009 thaanks for your help.So will a 600watt amp be 400rms?
raytard Posted October 1, 2009 Report Posted October 1, 2009 no a 400wrms amp will be a 400wrms amp find an amp that says 400wrms at 2ohms and you're set Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
troy Posted October 1, 2009 Report Posted October 1, 2009 THIS :D retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Twistedchild420 Posted October 1, 2009 Report Posted October 1, 2009 no a 400wrms amp will be a 400wrms ampfind an amp that says 400wrms at 2ohms and you're set Don't just find any amp that says that....check the fuse rating also ,lol My POS Bass machine-2003 Hyundai Santa Fe on some shitty 22'sBed Liner Paint Job-Pioneer AVH 3200DVD4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)4 Arc Audio XDI2000.1 for the woofers6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters2 Arc Audio KS300.4's for mids and tweets1 Arc Audio ALD 10v Line DriverAll Audiotechnix Power wire1 DC Power 270XP High Output Alternator1 XS Power D3400 up front....6 XS Power D3100's in the rearAir Lift 1000 Bags in rear to help with suspensionIf your still reading this GFY.......
unknown123 Posted October 2, 2009 Author Report Posted October 2, 2009 lol thanks guys =) i will try to find a good amp =p
