well what i have been doing is having the sub vol. at 4 and setting it till the voltage just starts to drop ( and its as loud as i want it then) but i have 2 amps ill be running so i cant do that and need to gain match them
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Anything less than 14 on my Alpine puts me into negative attenuation.
When he goes from a 0db recordding to -3db recording he will have to turn the gain on the amp up a little. If I'm not mistaken RF recommends setting up with a -5db recording with its 360.2.
Why?
Well not all if much music content is going to play at or near a 0db recording. In MY WORDS useing the -db recordings help cut out some of the headroom and with subwoofers quite honestly makes them sound louder with very little if any harm at max volume.
I iuse a 0db recording because I use the Punch Bass remote knob that came with my amp and setting it at 0db allows me plenty of room to play with my bass boost without clipping the shit out of my amp.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
alright looks like ill used a 70 hz tone 0db then? lol with it on 4 out of 8?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
This is why i like oscopes... takes most of the trouble out of things, cept gain matchin.
wats your electrical system like to set the gains till your voltage drops.
Am I still not explaining this well?
Are you getting it at all?
EDIT: anyone am I making sense?
Edited by ISO
Why is your voltage dropping?
You do this with everything (all subwoofers NOT hooked up) there should be no voltage drop.
140 amp alt 2 red tops in the back and a stock upfront 2 runs of 1 gauge to the rear
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
IMO you are better off with a 50 hertz tone.
I know I didn't explain things well but surely you are getting the idea?
I'm passing on the electrical to the next guy. There is no reason you should be haveing a voltage drop when setting things up unless you are doing it by ear because nothing should be hooked up on the amps outputs if useing the DMM method or O-scope method.
Edited by ISO
no nothing will be hooked up i dont want to go threw setting all the other eq "bands" just to match all the outputs im sure theres an easier way
if i have a 50 hz tone... ill be setting the output of the amp to 77vrms correct? ill have the sub settin on 4 out of 8 becasue i know maxing it out isnt the best of ideas and 0 is completly off and i woul dlike a little room to turn the bass down if need be
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
