Marlo Stanfield Posted October 4, 2009 Report Posted October 4, 2009 X2 OR LVL4 XLs If the OP is planning on running like 3k or so daily it would be pointless to run a pair of LVL5 10s on that power... LVL4s would be more in the power range or LVL4xls would be playing it on the safe side. Regardless of the choice the LVL4 + 4xls would be louder than LVL5s on 3k daily without a doubt. Plus 2 LVL5 10s won't quite fit into his $600 price range for subs. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
gary2k7 Posted October 4, 2009 Report Posted October 4, 2009 But neither sub(s) will do ok in that enclosure... It's wayy to big and the port area is too much also, for the pair or a single 12. Even for a single 15 i wouldn't recommend that amount of port area unless it was in a massive enclosure w/ a ton of power. lol when i posted that i didnt see how big his box was lol...got added while i was checking prices for that stuff lol
gary2k7 Posted October 4, 2009 Report Posted October 4, 2009 If the OP is planning on running like 3k or so daily it would be pointless to run a pair of LVL5 10s on that power... LVL4s would be more in the power range or LVL4xls would be playing it on the safe side. Regardless of the choice the LVL4 + 4xls would be louder than LVL5s on 3k daily without a doubt. Plus 2 LVL5 10s won't quite fit into his $600 price range for subs. wat if he were to buy 1 12" lvl 5 for now(get the right size enclosure) then an ad3500 and then save up and add another amp and sub? wouldnt a 12in lvl 5 fit in his budget? i thought they were like 550 or sumthing, i could be wrong tho. but i lvl 5 with 3000rms daily would slap pretty dam good imo
Marlo Stanfield Posted October 4, 2009 Report Posted October 4, 2009 wat if he were to buy 1 12" lvl 5 for now(get the right size enclosure) then an ad3500 and then save up and add another amp and sub? wouldnt a 12in lvl 5 fit in his budget? i thought they were like 550 or sumthing, i could be wrong tho. but i lvl 5 with 3000rms daily would slap pretty dam good imo That will end up with a much bigger budget in the long run and not just on sub(s)/amp(s)... The electrical to back up 7kw daily will be pretty significant. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
gary2k7 Posted October 4, 2009 Report Posted October 4, 2009 That will end up with a much bigger budget in the long run and not just on sub(s)/amp(s)... The electrical to back up 7kw daily will be pretty significant. that is true sorry i wasnt adding everything into consideration. wat about the aq subs? arent they pretty good? havent had any personal exp but maybe you guys have.
StreetSlappah Posted October 4, 2009 Report Posted October 4, 2009 the xls then ftw Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center] Build Log http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/ 2005 subi STi 380whp 355whp 17" gold bbs 5% tint all around w/sunglare strip JVC dvd double din Knuconceptz 4ga wiring XS Power! Big 3 8" SAv2 d2 1800 audiopipe
