Anyone ever use this amp or any Cadence amps? Does it do rated? Was going to trade my ap15001d for one. Here are specs:
4 Ohm Competition Rating
1 Ohm Mono Power
Frequency Response
Signal/Noise Ratio
Damping Factor
Minimum THD
Channel Separation
Input Voltage
Dimensions 50 Watts
1200 Watts
10Hz - 40KHz
>100dB
> 200 @ 100 Hz
<0.044%
>65dB
150mV - 8 Volt
19” x 10.75” x 2.4” (LxWxH)
I'd run the Audiopipe way before either of the amps u listed.
Pioneer AVIC-N2
Thanks guys. The only problem I'm having with the AP is the 45 degree terminals. Can't fit 0 gauge in them and can hardly fit 4 gauge. 4 to 0 reducers, impossible to fit.
Trim the wires going into it, not the best way to do it but it does work. I'm very surprised that reducers like this won't fit. - http://www.darvex.com/PAC104S/Sound%20Ques...%20Reducer.html
Pioneer AVIC-N2
I have those exact one's but the way the AP is made, there is this thing that sits right in the way of the terminals. That "thing" is where you would screw the amp down. I though about just breaking/cutting it off, that would solve the problem I'm having.
If u do cut that piece off, then how will u properly be able to mount the amp afterwards??
Pioneer AVIC-N2
  • Who's Online   1 Member, 0 Anonymous, 670 Guests (See full list)
