Measure the width and length (in feet) and multiply them. Then add 20%. To add 20%, just multiply by 1.20. That's the way I do it.
Edited by 1992Chevy K1500
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
k i have the numbers but how do i figure out how much i need?
Re-read my previous post. Just multiply the numbers (make sure they are in feet). Then find whatever kit/pack that is closest to what you need. You may have to buy more than one kit to get close to what you need.
15.4" widescreen
What it does:
if you did that those numbers are in feet. then you can go to second skins site and see what size to order
98 Jeep Wrangler
33x13.50 super swamper LTB's
Memphis M3 15"
Memphis MCD1000
Optima yellowtop D34/78
Bass Race 129.9
(LBZ Duramax in the future)
Since when is 20% represented as 1.20? 1.20 is 120%, not 20%. For 20%, it is 0.20
*your mom* <- your mom is my signature! daaaaaaang!
It's not. The 1 represents the orginal amount. The .20 represents the 20%. Say you come up with 36 sq. feet.
36*1.20=43.2
Or the harder way:
36*.2=7.2
7.2+36=43.2
Same answer either way, just the way I mentioned is much easier.
15.4" widescreen
What it does:
I rounded up on all my numbers as well .. what does adding the 20 % do give you some extra?
Yeah. It'll allow you to overlap in problem areas.
15.4" widescreen
What it does:
  • Who's Online   1 Member, 0 Anonymous, 1355 Guests (See full list)
