Demo402 Posted October 4, 2009 Report Posted October 4, 2009 I'm looking into getting a 15'' fully loaded Btl (D2) and i was wondering what would be a decent matched amp that would run at 1 ohm? i have not done any research on this just wondering if i can get some info on the way to go! Thanks. Honda Accord 4 Door Current System - (2) 12'' Mtx Thunder 5500's (1) Alpine Mrp-m1000 @4Ω (1) Pioneer Deck Deh-3500 (1) American Legacy 1.0 Farad Capacitor (1) Stinger Voltage Meter (Blue) Big 3 Knu 1/0 Box 3.4^3@37hz Youtube.
davewms9605 Posted October 4, 2009 Report Posted October 4, 2009 From what ive learned on here, you would need to upgrade your electrical if youre going to put a BTL 15 cause they need alot of power. Big "3" done in 1/0 gauge is first. Upgraded hi amp alt is next. An amp for that id recommend a Sundown SAZ-3000D and a couple dry cells!! And make sure you have the correct ported box! If you cant afford a new Sundown, go to db-r electronics and get a refurb. Or you can go Audioque AQ2200D if a Sundown's to costly! Good luck. Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!!
Demo402 Posted October 4, 2009 Author Report Posted October 4, 2009 From what ive learned on here, you would need to upgrade your electrical if youre going to put a BTL 15 cause they need alot of power. Big "3" done in 1/0 gauge is first. Upgraded hi amp alt is next. An amp for that id recommend a Sundown SAZ-3000D and a couple dry cells!! And make sure you have the correct ported box! If you cant afford a new Sundown, go to db-r electronics and get a refurb. Or you can go Audioque AQ2200D if a Sundown's to costly! Good luck. i was looking into the Aq 1200D but i don't think that's enough power, and i was planning on 1 other batt, and the big 3, thanks Honda Accord 4 Door Current System - (2) 12'' Mtx Thunder 5500's (1) Alpine Mrp-m1000 @4Ω (1) Pioneer Deck Deh-3500 (1) American Legacy 1.0 Farad Capacitor (1) Stinger Voltage Meter (Blue) Big 3 Knu 1/0 Box 3.4^3@37hz Youtube.
Mr Bigolsworth Posted October 5, 2009 Report Posted October 5, 2009 yea im still doing some Research on the Fi BTL as well. i wanna do 2 18's on 2 MD3D's Each. 2002 chevy avalanche Currently have: 2 dc xl 18 set of T2652-s scv-6k Ct sounds 75.4 270a mechman xp3000 d3400 Wanted: saz 200.4 Second set of T2652-s D3100's deadner
