Questions about this battery
So Ive seen this before, i searched, but i couldnt find anything
For my spring setup, im looking to address a glaring hole in my setup which is my electrical. So bottom line i need to feed my SAZ3000D
i ahve stock electrical + kinetik 1400, after running some numbers, ill need at least 2 2400's to really be good electrical wise
i was at walmart i remeber my friend ran 5 of those evermaxx marine deep cycle batts because he needed quick power for a show.
they are like around 70 bux each a/h of 123 which is similar to an hc2400 (128 ah) i think
whats the consensus on using these? i know kinetik is designed for it etc etc but again im on a budget
im sure it will be ok, but i just want some outside opinions
also they will be in the trunk sealed off from the cabin so sulfur is kinda blocked from the cabin
last? : mixing these w/ kinetik = ok? i have the 1400 with my stock starting bat like alot of ppl so it should be ok..?
any feedback is appreciated
P4Killer :P
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Go ahead and get the kinetiks. Those wet cells aren't that good. A freind of mine tried one and he said they're not worht the money. Not to mention, when charging they give off hydrogen gas, which could blow up in a closed space. Which equals instant death for anyone inside the cabin even if it is sealed off.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
lol thanks
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 489 Guests (See full list)
