Is this a good amp? Kole KX1 5500D
barros57
I just bought this yesterday for cheap. I was wondering if it is a good amp? Will it push a Orion HCCA 10" or a 15"? Should I sell it?
Thanks guys
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
since you already have it i say run it through its paces. see what it can do.
normally kole is metioned with such brands as boss, pyle, rockwood, kenford.... just not oo brands.
do some power tests on it. lets see what its got
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Haha i had it hooked up to my 10" L7 last night to make sure it worked and everything. I was really scared i was going to blow the l7. It seemed to have some good power. The circuit board also looks well made and 5 30amp fuses is a pretty good sign right? I wonder if it will actually make the 3200 watts @ 1 ohm
SPECS
KX Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 watts x 1 chan.
Fully regulated PWM MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 45 Hz)
High speed digital circuitry
Bridging synchronization capable
Preamp RCA outputs
4-way Protection circuitry
System distress indicator
1 ohm Stable
Nickel-plated screw terminals
Variable low-pass filter (50-150 Hz)
Subsonic Filter (60-200 Hz)
Frequency response: 15-150 Hz
Dimensions: 17.5"L x 11.7"W x 2.2"H
4/8-gauge power and ground leads recommended.
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
It is only fused with 150amps of fusing, so I dont think it will do anywhere near 3K, maybe 1500rms on a good day.
And I noticed why does it recommend 4/8 guage power and ground wires, If it was a true 3000rms it would have 0G inputs.
Also 10" L7 is rated at 600rms, so even if the amp was only putting out 1400rms, that is still more than double its rated rms.
¿ǝɯɐƃ ǝɥʇ
Looks like a Fosgate ripoff to me.
LOL I didnt even notice that
¿ǝɯɐƃ ǝɥʇ
I wonder how the guy i bought it from managed to blow a 4000 watts max 2000 rms orion hcca sub with this thing.
lol yea, i just noticed that too. It does look like a fosgate rip off
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
Probably by clipping the bejeezus outta the amp.
Too many projects, too little time...
  • Who's Online   0 Members, 0 Anonymous, 16919 Guests (See full list)
