lgnmgr Posted October 8, 2009 Report Posted October 8, 2009 Ok so i've popped 5 fuses now!!! all my connections were made from amp to battery and ground i am running 0 gauge and the first fuse i popped was a 250 amp and the other 4 were 200 amp... all i did was disconnect the battery positive then put fuse in then tried reconnecting the positive and it blew then i tried disconnecting the battery negative and keeping the positive hooked up and when i put the negative on it popped... i know im probably doing something wrong but i cant think of any other logical way to do it. please help, thanks.... I've checked for grounding the power wire and there are no obvious spots, i've checked all connections and they all seem good. im startin to think the amp has a short or something.... PLEASE HELP. thanks
Crump Posted October 8, 2009 Report Posted October 8, 2009 What amp you got? does it pull more than 250? check your firewall for a snag in the wire. Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Guest Posted October 8, 2009 Report Posted October 8, 2009 first thing i would check in that situation is frayed power wire. even a single strand can cause that fuse to pop
HaMSaMMiCH Posted October 8, 2009 Report Posted October 8, 2009 Definitely sounds like you have a short somewhere. You need to check the entire run of power wire for breaks, as well as all of your connections. CAUTION! POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
bigredishott Posted October 8, 2009 Report Posted October 8, 2009 Def sounds like short. best luck finding and fixing! Alpine CDA-9847 HU F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels R Highs Infinity Ref. 9622i powered by HU 3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
lgnmgr Posted October 8, 2009 Author Report Posted October 8, 2009 ya i checked the entire power wire and couldn't find any snags or anything... thats why i was thinking it mite be a short in the amp itself?
lgnmgr Posted October 8, 2009 Author Report Posted October 8, 2009 i have the clarion dpx11551 im gonna hook it up to my brothers wiring tomorrow and see what happens
