need help with wiring!!!
Ok so i've popped 5 fuses now!!! all my connections were made from amp to battery and ground i am running 0 gauge and the first fuse i popped was a 250 amp and the other 4 were 200 amp... all i did was disconnect the battery positive then put fuse in then tried reconnecting the positive and it blew then i tried disconnecting the battery negative and keeping the positive hooked up and when i put the negative on it popped... i know im probably doing something wrong but i cant think of any other logical way to do it. please help, thanks.... I've checked for grounding the power wire and there are no obvious spots, i've checked all connections and they all seem good. im startin to think the amp has a short or something.... PLEASE HELP. thanks
  • Who's Online   0 Members, 0 Anonymous, 1172 Guests (See full list)
