Calling All Box Desingers!!!
white513
Hey my name is Matt.
I already asked for box designs and got some good designs, but I asked in the wrong section. I figured I should ask in this section now. I have 2 15'' MTX Thunder 4500s and my max specs are 40 inches long 20 inches high and 20 inches deep.
Here is my previous post. I would also like to have the port at the bottom of the box. And i definitely want some of these :hairtrick: :hairtrick: :hairtrick:
Thank you, Matt
2006 GMC Envoy
BOSE Audio
G/l doing a hairtrick w/ 2 4500 15s... A lil too buzzed right now to do a design, but something like 7-8ft3 @ 34hz w/ 100sq in of port would be perfect. If you can fit something of that size.
Pioneer AVIC-N2
u cant have the port all the way along the bottom... too much friction/ur breaking the 1:8-9 rule
example
if port is 2 inches wide the max the height should be is 16-18"
u have 7.6cuft before any displacement
ur not gonna get hairtricks off that equipment, it takes mroe than that
6.17cuft@33hz is what i worked out with those dimensions
12sqin/cuft... 74sqin port
4" wide port on either side of box
port piece 1 is 14.5"
port piece 2 is .75"
  • Who's Online   0 Members, 0 Anonymous, 3430 Guests (See full list)
