Is upgrading the wires from say 12ga to idk.... 8ga a good idea? The wires I mean are the one you hook up from the subs to amp.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Unless you're running crazy power I wouldn't bother. Crazy being maybe 4k+
nah only running a little over 3k. So it wouldn't be worth the trouble?
.5 ohm and dc amps have no internal fuses. Currently have 3 runs of 4ga with 2 150a fuses. Should be upgrading to 1 run of 1/0 Kolossus Fleks Kable from my red top battery to a D3100 in the trunk. Need to get some 300~350 anl fuses as well.
Edited by SojiaRaggs9000
is this board similar to the sundown 3000? if it is you can probably get over 4000 watts out of it and i have heard that if you run an amp at .5 you double the 1 ohm out put
Don't get me to lying ... heres the specs
PAI 3000.1
RMS power, 1 ohm mono - 3000W x 1CH
RMS power, 2 ohm mono - 1500W x 1CH
RMS power, 4 ohm mono - 750W x 1CH
RMS power, 2 ohm linked - 5400W x 1CH
I think this is a pic of the guts.. not 100% sure
Yall run 8ga......Sssshhhh.......I run 4/0 speaker wire LAWLZ.
¿ǝɯɐƃ ǝɥʇ
lol its funny you say that... I was gunna just take some wire from the 3 runs of 4ga i currently have and use it when I get some 1/0 Kolossus Fleks Kable. Its free that way lol... saving that $$$ lol.
  • Who's Online   0 Members, 0 Anonymous, 3033 Guests (See full list)
