well, the only reason i asked is because my car idles sometimes at 800-900 RPMs, sometimes (after it has been running for a while) 300-400 RPMs, and sometimes after ive been driving for 10 minutes or so it will idle at either zero or 100 RPMs. I dont really know what the cause of it is and I was wondering what would happen if i changed the idle RPM
It's probably not really idling that low. It sounds like your Tach is fucked up. Zero RPM is OFF, and I don't know of any motor that idles at 100 RPM. Most big V8's that idle WAY lower than imports only get down to 500. V6's and 4cyl are typically between 600-900
and ALOT of cars have what is called "high idle" right after start to help the car warm up and get better compression, If it really is idling that high when you start it, as it sounds like your tach isn't giving you any sort of realistic idea of where it is idling....
CAUTION!
POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
1999 Acura Integra 1.8, the alternator is an excessive amperage (200 A) alt that i have had for 2 years and havent really even worked it that much
Your tach is DEFINITELY broken. That Honda motor probably won't stay running under 600RPM.
CAUTION!
my corolla's 1.6 idles at about 700rpms after warmed up (google) so theres no way yours can idle as low as you say.
i vote (again) on broken tach
well, after driving for 10 minutes maybe, the car is warmed up (or whatever, IDK, im not car tech savy), i will push my clutch in for whatever reason and the RPM needle will drop all the way down, what is the tach so i can look into it?
Baylor University
Accounting
the tach (or tachometer) is the needle with the numbers 1-8 generally on it. it usually has about 4 little white mark notches between each number
edit: ^^ on the left
Edited by Krannyman92
Tachometer is the gauge that shows your RPM's.
CAUTION!
so what would i replace to fix it?
And i guess that measures the RPMs of the alternator?
Baylor University
Accounting
no, of the motor.......
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
my toyota idles at 450-500....
yeah the technical term is called "closed loop/ open loop... google that when you want to learn something...
probably
Edited by treossi
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
and no it doesn't read alternator rpms... it measures engine rpms off crank sensor
  • Who's Online   0 Members, 0 Anonymous, 1261 Guests (See full list)
