Robola 46's BERYLLIUM BMW 323ci.
I needed to adjust the backside of the poly part. Now it fits nicely and is just the way i wanted it to be.
Here you can see the crossovertray while opening.
Picture of the inside of the place where the crossovertray will be mounted in.
Next thing to do is shape the front of the tray so that is will fit for 100%.
i likes me some audio stuff...
It was pretty cold, but i found a way to keep me warm.
This is what my workshop lookes like after sanding on the tones of metallica's death magnetic.
As you can see, i've used a can of spraypaint to sand the curves.
Here's a picture of the finished part to fit on the front of the crossovertray.
On this picture you can see that it fits perfectly.
The carbon part that will be mounted on the front of the tray is sanded and ready to be clearcoated.
In the meanwhile everything is removed from the car, so that it can get a final touch .
The carbon is already covered with epoxy.
I've been looking at the crossovertray, and it misses something...
In the front you can see the lights that i will be mounting.
This is what will be mounted inside of the crossovertray.
It will be covered with carbon.
These 2 alulinium plates will be used to guide the connectors from the crossover..
The inside of the crossovertray is also covered in carbon .
I've bent 16 massive kopper tubes to connect the focal crossovers.
Then i made the screws shorter so that it all looks better.
The holes in the aluminium are equiped with LED holders. Now i have a good isolation between the the kopper and the aluminium.
at the end of every kopper tube i'm going to fasten some speakercable.
The aluminium part which will become the frontcover of the crossovertay has been chromed .
The aluminium parts which need to guide the kopper and the piece inbetween the carbon will also get chromed.
This will make it easier for me to keep everything clean in the future.
These alumium plates are made to be mounted on the side of the crossovertray.
The previous ones have been removed because they didn't completely fit the rest of the design.
De aluminium parts on the side of the crossovertray have been replaced so the they have the same look.
Attention to detail...
I've used the old router.
Afterwards it all got polished.
