uhoh_45 Posted October 23, 2009 Report Posted October 23, 2009 so i wanna start a build on my buddys 1993 ford ranger but never get the time to look at it cause hes usually busy with school so i was wondering if anyone has any pictures of where they ran there power wire so i can just go straight to the spot and not spend all that time finding a spot , thanks alot guys R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
kl0wn Posted October 23, 2009 Report Posted October 23, 2009 Well, my last system was in a 90 ranger, I had my power wire running underneath my passenger seat and up thru the firewall right there beside the battery, had to cut a new hole and fill it in though 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
jrplayer36 Posted October 23, 2009 Report Posted October 23, 2009 I have a 2001 ford ranger and mine ext cab and my wire is ran in between my two seats through the firewall. jrplayer36
uhoh_45 Posted October 23, 2009 Author Report Posted October 23, 2009 you guys dont happen to have any pictures would you R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
kryptonite Posted October 23, 2009 Report Posted October 23, 2009 if you look where the gas and brake pedal are, you should be able to find a flat section of firewall, just eyeball measure it to see how far from the floor pan it is, check from under the truck up that far using where the brake pedal goes to the master cylinder as a reference point and you should be able to find a spot there somewhere, atleast that's where mine was in my 2000 DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
uhoh_45 Posted October 23, 2009 Author Report Posted October 23, 2009 i appreciate the help fellas but does anyone have any pictures? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
