There many great subs out there that are in a better price range than w7's you'll learn alot here.
truf man just sit here a little youll learn alot more and i dont think youll want the w7 anymore
setup looks clean jl audio is good stuff but over priced for what you get if you want to make it louder check out some the installs on here should give you some ideas and ppi is the bomb also they should be coming back next year
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
So today I went and had my car metered. 138.2db at the windshield. Im
pretty disappointed with that number. I had a jeep with 2 12w1's and crossfire
200.1 amp hit 139.1. I know a lot of my problem is where my amp rack is. also
my back seat doesn't flip down. I am debating on what the next step will be.
Maybe a ported box will be better. But I suppose for what it is its not to bad.
There pretty much is only 2 ways to get good numbers out of a trunk set up:
1) Have seats that fold down (But you already said you don't have)
and
2) Port through your rear deck (Which is both of our options for good numbers)
So before you get a whole new system try that and see the type of numbers you pull out of the one you currently have.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
Not really into jl anymore besides the 12's I had I only had
50.00 in. I would upgrade subs but I don't want to have to
upgrade amps too. Most of these subs, fi, dc ect... are way
more than what my amp can push. Hell I think my amp is only
800rms at 2ohm and 1200rms at 2 ohm.
hmm?
Alpine CDA-9887
15" FI BL
JBL BP1200.1
Rockford Fosgate p142 4" front
Rockford Fosgate p1S652 6.5" rear
Optima D35 yellow top under hood
Big 3
all in a 1997 Toyota Tercel
and
port through rear deck, what does that mean?
So a buddy came down and bought a crossfire amp from me today
and we were fuckin with my system. We played it with the center
compartment up, then while it was playing we flipped it down and
there was a noticeable difference. So my decision is to find a back
seat out of a 300m that flip down and lay my amp rack down flat and
add some fans. My amp is only 2ohm stable and Im running it at 1ohm
so it gets hot in about 20 minutes and goes into protect. So fans are def.
needed. Also Im thinking about some hush mat or fat mat. Im thinking
with all of this I should see 140+. Which is awesome for a 400.00 watt
amp. If Im happy with the number after that then I will keep the setup
I have until I blow the subs then I will try something new. So in a few
days I will get some pics of my back seat swap.
