rival904's F150 Build. UPS delivered, page 40
How, the FUCK do you get them so perfect?! :help: :help:
Top Secret sir.
I used a wire wheel on a bench grinder after the solder was all dry.
Cleans em up nicely if I must say so myself.
3:1 ratio ... I can't see the pics cause I'm on my phone but is it only 2 15s? How much port area and what's tuning?
4 15s....
Tuned at 45hz.
Port is 8.75x46.50
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
Just sat down and looked at all the shit I gotta do to the truck....
take the dual alt bracket off and try and get it lined up a little bit better
re run all my power and ground wires
build my box
order my subs
weld my roof back up
get a new belt because the old one snapped
replace my tensioner
build my amp rack
glass my doors
order my mids and highs amps
*sigh*
Got a long ways to go...
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
I lost count.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
45 hz tuning??? that thing is gonna murder the lows bro,what 15´s are you gonna use? best of lucks on this rebuild hommie!!! :drinks:
wow agian? hahah but what subs are you using?
amp is SUPER SEXY!!!
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
I would personally start out with 1.5 sealed and 5 ported to make less work for yourself in shrinking the
box down if you are looking to run
more power.
Build looks good tho. Building and learning as long as you go I like it. :) I'm just giving a little advice, I'm not critising. Another thing I would do is cove the bottom front corner where the woofers unload to, only to increase pressure on the port and decrease back pressure on the woofers.
Roseville, CA
I tried the 1.5 sealed before. It was meh. I don't mind shrinking it down, its easier than making it larger! Also the front wall where the port is has a HUGE 45* on it, 6.5in wide... I can make it bigger if needed.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
Top Secret sir.
4 15s....
Tuned at 45hz.
Port is 8.75x46.50
still doin the 3500s?
the 45 hz tuning should pound the lows and move some air, i think cricket is tuned at 45, maybe it was 50 ..
406 square inches, id do a little more then cut it down until it stopped gaining.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Can't make the port bigger unless I cut the truck. And I ain't cuttin ish yet.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1707 Guests (See full list)
