problems with brigdging amp...please help
So I think the reason your voltage drops is the extra draw you've created by bridging your amp plz someone correct me if I'm wrong. I don't think your amp will do one ohm bridged. If it will, then first thing I would do would be the big 3 to try and get rid on some of the voltage drop. The amp could be shutting down due to lack of enough power but my guess is that your amp wasn't meant to do one ohm bridged.
Briding the same as strapping? If so...this is the one of the specs off of onlinecarstereo that cccmaa posted
"Strapping Capability: Strap Two Amps Together for Twice the Power (2 Ohm Stable)"
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
Technical Specification
RMS Power Range : 600 Watts
Number Of Channels: 2
Maximum Power: 1600 Watts
Built In Crossovers: Yes
Channel Separation: Yes
Features
Max Power @ 2 Ohm: 800W x 2
RMS Power @ 4 Ohm: 300W x 2
Bridged Power @ 4 Ohm: 1600W x 1
Signal-To-Noise Ratio: 103dB
THD at RMS Output: 0.01%
Damping Factor 125+
Dimensions (10"W x 2-7/16"H x 11-7/8"L)
Tri-Mode Operation
Bridgeable
2 Ohm Stereo Stable
Variable Low Pass Crossover: 40-150Hz
Fixed High Pass Crossover (200Hz)
Variable 0 to +18dB Bass Boost
Variable Input Gain Control
Power and Protection LED Indicators
Thermal, Overload and Speaker Short Protection
Line and Speaker Level Inputs
Chrome Plated RCA Connectors and Screw Terminals
Remote Subwoofer Level Control
Frequency Response: 9Hz - 50kHz (+/- 3dB
99rangerkid
The one I posted was an example of why these amps are not good at all. Not the exact amp ranger has.
And no it's not the same as bridged, bridged is done on one amp. When you strap an amp you take two amps that are strappable and make one amp out of them creating more power and also creating a higher required ohm load. Amps that are strappable have a master and slave setting one them and depending which amp is sending or recieving the power from the other would determine which amp would be set to which setting.
Yeah I know what strapping was, never read up on what bridging was, thought it was just a different word haha, but I looked up bridging a few minutes ago and figured out what it was, thanks for clearing it up though!
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
here is another version of the diagram that etaks crew posted and is how you need to wire your amp and subs up
97 Honda Civic Sedan
Rear disc brake conversion
2" drop
17's
lots of exterior mods
SYSTEM
SoundStream VIR-5850 Dvd player
RE 6x9's and 6.5's
Soundstream DTR4.500
Soundstream DTR1.2200
8" RE-x in a t-line
Kinetik 1800
Plans
4-SA-8's
Another Kinetik
High output alt
My Cardomain
  • Who's Online   1 Member, 0 Anonymous, 871 Guests (See full list)
