Pound That Sound
that's the enclosure I would use....
if you want a box I would need your max width
max height
max depth
of the space the enclosure will sit in..
and configuration of box..up firing or rear/front firing depending on the type of vehicle
and the small patameter speck sheet for the woofer
contact me thru my link with the info if you wish to proceed
i spend about 50% of my time in Northern California. and the rest in Northern Nevada. Iuse to work there in Las Cruces back in... 03. I worked for security concepts over off salano dr. the guy that owns that security company also owns welcome inn bar.
IM A LOW LIFE SCAMMER SO I WAS BANT....TEH HAMMA is NOT my friend
  • 3 weeks later...
the exchange rate is about 10% right now
you have any pics of a 4 cu ft per woofer 8 cu ft total ported dual 15 boxes???
for a pair of RF T115D4 subs...
a 1.5" thick baffle (center of baffle is 2.25" thick)
and there is a brace between the port and rear wall
Posted Image
Posted Image
Posted Image
Posted Image
I'll update the pics when I am finished
