So a few days ago i posted that my wires going to mu amp, 1/0 g, were to big. Some ppl said get some reducers. I did. The pos and neg terminals are mpther fkn close that the reducers cant fit in next to each other. So i can only use ome reducer. Anyone know how to fix this? Im starting tp regret buy RF... I bought it thinking i would not have this problm. I thnk i should bought an AQ or somethimg and sabed $150.
Tin the wire with solder till it's coated all the way through. Then use a bench grinder to grind it down till it fits.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
just cut the wire down to size so it fits.... its just fine to do that as long as u make sure there are NO frayed ends
its crazy to think u need reducers, they are just easier
and its a good amp... no worries.... aq1200d has 4g input as well
Edited by Decaf
Bend the reducers?
SUCCESS is a decision, NOT a dream. You have to name the price you are willing to pay to get it.
"You didn't have an ice pick on you? Amateur. " -- Wax from Fchat.
Did you ever try the Zip Tie Trick I posted? If it doesnt work you can do what Decaf said.
¿ǝɯɐƃ ǝɥʇ
i domt have the resourses to that...
Describe frAyed? I have most of it jammed it there on the pos, i cut aromnd tto make it thinniler but i didnt knw if this was ok to do.
Bend the reducers?
They are not long enough.
yes, i did. It helped a little, thank you for that tip. Right now i have my pos wire cut around until i cpuld fit it in after usimg the zip tie trick. Then my neg i have the reducer on.
Okay......And by Frayed I believe he means when you put the wire in, if there were little strands sticking out of the terminal, like strands that could potentially short to the Negative or Positive terminals.
¿ǝɯɐƃ ǝɥʇ
Just make sure there is not even 1 strand bridging the 2 terminals. Otherwise ZAAAP!!
15.4" widescreen
What it does:
