ok guys, i know there are some guys on here that know their shit whhen it comes to this stuff...
im thinking about attempting to install my alarm in my blazer. its a 2001 xtreme. what all do i need for the installation? are there any extra modules i need for the remote start to work? where can i get a wiring diagram? ive never attempted an alarm before and im kinda nervous but i want to learn how so i dont hav to depend on a shop to do my alarms. i appreciate any help...
the alarm is a viper 5900 w/ remote start. thanks again
EDIT: i had this on a 2003 taurus and i havnt touched it since i took it out of there. i cut all the wires where they were soldered into the factory wires. i dont know if that is relevant or not but i thought i would mention it.
Edited by pmpnu2
2001 chevy blazer xtreme
my blazer xtreme build
On top of all that, my little sister is marrying a real fuckin winner tomorrow
I've gotten that much wood just viewing this thread. :blush:
2001 Chevrolet Blazer DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts red + ignition harness
Second 12 Volts
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory
Third Accessory
Keysense
Data Bus yellow (resistor code), orange/black (ground) Passlock 2 Passlock sensor on ignition key cylinder
Can Bus High
Can Bus Low
Can Bus Sw purple data data link connector under driver dash, pin 2
Power Lock lt. blue + brown plug at BCM
The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side.
Power Unlock white + brown plug at BCM
Lock Motor gray 5wi driver kick panel
Driver Unlock Motor tan 5wi driver kick panel
Passenger Unlock Motor tan 5wi passenger kick panel
Parking Lights (-) white - lt. blue plug at BCM
This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground. The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side.
Parking Lights (+) brown + lt. blue plug at BCM
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight purple/white - purple plug at BCM
AutoLights
Reverse Light
Left Front Door Trigger - BCM
The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side. Use tan for the drivers door located in pin B4 of the purple plug, orange for the passenger door located in pin B2 of the purple plug, and dk. blue/white for the rear doors and rear hatch located in pin B11 of the lt. blue plug, must diode isolate these wires.
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision use door trigger
Trunk/Hatch Pin pink/black - lt. blue plug at BCM
Rear Glass Pin
Hood Pin
Trunk/Hatch Release black - purple plug at BCM
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left) N/A
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm lt.green - purple plug at BCM
Disarm No Unlock see factory alarm disarm
Trunk Alarm Shunt
Tachometer white ac PCM
The PCM is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20.
Wait to Start N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense
Brake Wire white + steering column
Parking Brake
Horn Trigger black - steering column
Also found in the brown plug at the BCM on vehicles with a factory alarm.
Wipers
Left Front Window (Up/Down) blue - brown A driver window switch
Right Front Window (Up/Down) lt. blue - tan A driver kick, door harness
Left Rear Window (Up/Down) green - purple A driver kick, door harness
Right Rear Window (Up/Down) lt. green - purple A driver kick, door harness
There is your wiring diagram :)
As for modules look into a PLJX to do your passlock2 bypass for remote start... or a 555L will work also.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
All Products
Second 12 Volts
Second Starter N/A
Third Ignition N/A
Second Accessory
Third Accessory
Keysense
Can Bus High
Can Bus Low
Hazards
Turn Signal (Left)
Turn Signal (Right)
AutoLights
Reverse Light
Rear Glass Pin
Hood Pin
Trunk Release Motor
Fuel Door Release
Factory Alarm Arm
Trunk Alarm Shunt
Wait to Start N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Speed Sense
Parking Brake
Wipers
Shyne151 i have to say you are the mutha fuckin man!!! you obviously know your shit... thank you very much
on my 03 i needed a gm bypass
this is the i have
http://cgi.ebay.com/Dei-PLJX-GM-Self-Learn...=item3355504f68
thank you sir... ill have to check that out later on, i gotta take the daughter home right now. i appreciate the help...
No problem man! If you have any questions during the install process just post them up, I try to help as much as I can in this section.
Kenwood eXcelon 995
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
