Elemental Designs EHQS8 ideas
uhoh_45
so i recently got my 4 Elemental Designs EHQS8's back from my buddy they are in a shitty sealed box and i've decided i wanted to use them in my room
what do you guys suggest i do with them
i have a bit of room to work with so i was thinking somthing along the lines of a 4rth order under my bed
here are the specs for the sub(s)
im just looking for some impute on box designs
R.I.P!
(Nov-29-2009)
92 explorer
current build
really thats shitty looks like i'll have to use my 9515
R.I.P!
(Nov-29-2009)
92 explorer
current build
I use these subwoofers in my vehicle right now running off of a JL Audio G1300 (Rated Power 14.4 = 300 W RMS x 1 @ 2 ohm) and love these $5.00 woofers to pieces. They are in a 2cu ft box with a 32sq" port x 21" deep. I admit at the tail end of my 45 minute commute the smell of voicecoil fills the cabin of the Explorer, but being that I have run this setup for 8 months without 1 failure (I have 10 more of the subs on hand) I whole heartedly disagree with the post AZNBOI made.
My RE, ZAPCO, PPI flat piston and JL woofers are all hating on these cheap little freaks.
The box was initially used for my TREO TSi subs, just so happened after I roasted those I bought a dozen EHQS8 and the rest is history.
USE THEM
  • Who's Online   0 Members, 1 Anonymous, 479 Guests (See full list)
