imp of the coils will never go up as you break it in, if anything it will drop as it breaks in. Double check your DMM by touching the leads together.
i understand that but my amp did not go into protect before and it is now. same size sub, same impedance sub, same box, same amp, same amp settings. I know the subs are two completely different animals but I never through my BTL on this amp when it wasnt broken in.
your misunderstanding what is being said. the coils will always be at .6 on his meter. but the impedence changes as the sub moves. with the sub not being broke in, it is not moving very much. with a broke in sub the susp is much looser allowing the cone to move more. if you dont believe me hook up your dmm to a sub and get the reading. then push on the sub and see what happens.
I'm going to check all of the coil today and keep this thread informed.
My Videos
AQ + AA/Fi FTMFW!!!!!
just break it in by hand some more
iirc the protection circuit is at .6ohms but u can roll up burp down to .25ohm
have u noticed the amp goes into protect around ur tune frequency?
Edited by Decaf
I believe Kian on our team did. But we kept getting different readings each time we tried it. it was really weird. but he said i have a very low rise. i forget exactly what he said because it was a good 2-3 BBq's ago.
Yea that was weird.
All coils bounce back and forth from .5 to .6... :(
That is very low, But the lower the frequency you play, the lower imp rise will be. Also, i have have clipped the shit out of my old BTL, and the Ohm's never changed to the day it blew, i also use Dual 1 Ohm. Are both coils reading the same on that sub?
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
im tuned between 32-33 and its not shutting down there... I can play for a while then it will pop. other time it was instantly do it as soon as a note hits.. im using a lot of your songs to test this thing too btw haha
Yea that was weird.
yea. I have tested all of my coils even on the other sub and they all bounce between .5-.6
My Videos
