Is this something to be worried about??
Doylerules826
Ok I have I had this amp running and it started smoking, Immediately I turned it off, took it out opened it up and this is what I saw
I tested it today and it did power up however I didnt test if it had sound, But can some one explain me to what exactly that thing is/does and if I would be ok using the amp with it damaged and/or if it replaceable.
thanks
2000 chevy blazer
Avic n1
I have a bit of an idea, but I dont want to throw out any false info, probably Boon or another one of the Amp Guru's will chime in soon.
Edit: Also what amp is it?
¿ǝɯɐƃ ǝɥʇ
Fets are gone.... Don't turn it on any more.... the amps guys will chime in..
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Shit, that thing's well toasted. I'm having a hard time believing it still turns on! FETs must have just blown themselves out of the circuit completely, normally they go short-circuit when they die.
In fact, what, does it REALLY still turn on? The gate resistors are all smoked to hell so the drive circuit is probably fucked and the 494IC is probably freaking out. In fact I can see from the pic that your gate drive transistors are smoked, probably some of the resistors too.
Probably not a super hard fix for an amp tech as long as the traces are OK and depending on the reason that it blew up... if the power supply blew because the outputs blew as well then you may as well chuck it in the bin.
Seriously... it still turns on? Holy shit O____O
10.x volts fo' life!
:rofl: IDK why, but that face is funny. But I'm thinking the same thing.
We need vids for proof.
And I doubt the traces are ok. I've seen less damage then that where it couldn't be repaired because the traces were gone.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
