It's right on the FI website btw- Sub displacement(18" BTL) = .26ft3... Kinetik makes very good batts but tests have proven that XS does perform better with direct drop in testing. I'd also look into Northstar(which is what I run now) and I was very impressed with the differences after I switched from kinetik.
Btw what vehicle is the 18 going into?? I'm hoping the Tahoe because in the Altima it's going to be very very tight if that's the route you're going. If so I'd suggest just sticking with a 15 in there or running an 18 that can still perform well in smaller boxes like a Sundown Nightshade.
but ive made the box thats in there 2.9cbft .1 short of recommended an id like it to be louder on the 15 in there now..its louder but id like louder
http://www.youtube.com/watch?v=HzHkPv149hQ
http://www.youtube.com/watch?v=HA83EeTzZeI
That is a very small box for a that 15, especially on only 2000 watts. If you just made an enclosure like 4.5ft3 @ 34hz w/ 65in^2 of port you would likely see a significant difference in output. Just by raising the efficiency by making a bigger box + more port area you should see a pretty big difference.
Trust me spend $30 first to see what kind of output you can get from the 15, before you got out and buy a bigger woofer. It seems like you won't have enough room to build a proper box for an 18" BTL or the power to counteract and inefficient enclosure.
Pioneer AVIC-N2
where do i do that at??..pay $30 bucks to see what kinda output i can get ??
he said to spend some money to build a proper box and you'll probably get better output...and just saw your vids that is one nice tahoe,is the subs going in that ride?
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
well we talkin bout fittin a btl 18 in the altima with not much room to work with..the tahoe has 2 btl 15's an RF t4k on its wayy stock alt for now till
i get enough for new one
  • Who's Online   0 Members, 0 Anonymous, 1439 Guests (See full list)
