Yes you need 3 kits for that you want to do
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
Each bulb runs off of one ballast. Don't forget, the higher the Kelvin rating, the LOWER the output. Most car manufacturers use 4300k as it is the brightest on the spectrum. I run a 4300k setup in my civic and they are ridiculously bright.
2000 Blazer 4dr
-24" Boss 330s
-Lowered 2/3
-5000k Hids w Projector Retro
-Candy tails
-LED interior lighting
-20% tint 35% windshield
-Alpine 9886 HU
-RF P1462 Dash
-RF P1652 Front
-RF P1652 Rear
-Two 18" Fi BTLs
-MB Quart Onyx 4.80
-Two Audioque AQ2200Ds
-Xs Powerr D5100, 2 Powersafe G31s
-Knukoncepts 1/0 wire
-Mechman 270 Alt w Boost Module
-10.4 Net @ 28hz 140sq.inch of port
My Youtube Channel!!
so ima do 12000k high beams
10000k low beam &
4000k foggers
so do i need ballests for each bulb
or....
If you get bixenon bulbs with built in high/low beam in one bulb, then you will only need 2 ballasts for your highs and lows. (Also depends on your vehicle) Other than that each bulb requires a ballast. And please don't get 12000 kelvin.
I agree I think any thing over 8k-10k is too much
I recommend 6k to people when I install them
*1) AudioQue 20k
why wouldnt i get 12000k
2 jl audio 12w3's sealed
soon to be 4 level 3 15's
blow through
all dc audio
1. problems with cops
2. they decrease the light output
3. it turns the road blue/purple
4. they are very distracting to other drivers
You shouldn't really add hid to non projector headlights, but you can put them in your stock, but your not going to have a clean cut off line
Edited by Bigg Boy
*1) AudioQue 20k
^Exactly.
2000 Blazer 4dr
-24" Boss 330s
-Lowered 2/3
-Candy tails
-Alpine 9886 HU
-RF P1462 Dash
-RF P1652 Front
-RF P1652 Rear
-Two 18" Fi BTLs
-MB Quart Onyx 4.80
And this is not coming from someone who has installed a couple kits, I have personally installed over a hundred in the last year.
*1) AudioQue 20k
ok well i have my silverado n
i want to get h.i.d low n high beam
also yellow h.i.d foggers for sure
whut do you think i should get
blow through
all dc audio
