Amp turned off and won't turn on
Nirvalica
recheck your fuse and all ends of the wire.
either the wire isnt hooked up to the battery, the wire isnt connected to the fuse holder, the fuse is blown, or its not connected to the amp.
when it comes to your power wire, there are VERY FEW places where it could go bad.
Yea, I figured. I took the fuse out, it's fine. I made sure the connection at the fuse holder and amp are solid. I took of the connection at the battery terminal and cleaned it. I'll clean it some more. That's the only thing I can think of...
My Youtube Page. Check it out
The "SAV" - Sub-aural Assault Vehicle
Kenwood eXcelon KDC-X993
Image Dynamics CTX 6.5" Components
Q-logic 6.5" kick pods
CDT 6.5" CL-E6NEO Front door Midbass
Kicker ZX350.4
Knukonceptz SS Karma 4 channel 6m RCA
Fi Q 18" w/ brushed aluminum dust cap
7cu ft. ported box tuned to 28hz
Sundown SAZ-1000D
Iraggi 240 amp Amputator Alt
Big 3 in Monster 1/0awg
Second Skin Damplifier Lite on roof and front doors
did you test the fuse with a DMM while its connected to the batt? sometimes part of the fuse can disconnect internally and you can't see it with the naked eye. hook up one end of fuse to wire to the batt and test the other end of the fuse. what type of fuse are you using?
(2001 Dodge Durango R/T)
1- XS Power D2700
1-Alpine CDE-HD149BT (Head Unit)
1 pr.- Focal Polyglass 165v30 (Front Stage)
1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill)
1-Kenwood Excelon XR-1S (Sub Amp)
1-Kenwood Excelon XR-4S (Mids-N-Highs Amp)
2- JL 10 W3v3-4 (Subs)
-2.3 Cubes tuned to 32 hz
1-1/0 ga. & Big III in 1/0
140 @45 hz db drag legal
(2008 Toyota Highlander Limited ---build in the works)
1- Kenwood DDX470 (Head Unit)
1 pr.- JL C3-650 (Front Stage)
1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead)
1- JL XD-400/4 (Mids-N-Highs Amp)
1- JL XD-600/1 (Sub Amp)
1- XS Power D3400
1- JL 10w3v3-2 (Sub)
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
1- self-built Fiberglass sub enclosure
You are right. I switched fuses on the my bass amp and mid/high amp and the bass amp worked again. It was the fuse. I can't see at all where it is broken. Looks a little bent, though. Oh well, I guess I'll just get another. It's a 60 amp fuse. Does that sound right for a SAZ-1000d with 4awg wires?
My amp has 3 25amp fuses. I'm assuming that's equal to one 75 amp fuse? Should I go a little higher rating on the fuse?
Kicker ZX350.4
Sundown SAZ-1000D
1- XS Power D2700
1- XS Power D3400
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
sorry for my blank replies. im having issues.
1- XS Power D2700
1- XS Power D3400
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
something like this happened to me my amp just turned off completely after a bump, i know you said you checked your fuses but did you make sure under the hood that your wires were connected into the fuse holders still, mine came loose a bit and turned the whole thing off... just a suggestion
nevermind didnt read that you found out what it was
2000 Nissan Xterra
-Infinity 6020cs components
-Infinity 692.7 6x9s
-DC LVL 4 12
-AQ1200
-Pioneer DEHP860MP H/U
-4 channel amp for mids and highs??? I need some suggestions
I would keep running the 60 amp, better your inline fuse die then your amp. I always do that for customers, since nubes tend to beat shit. Otherwise get really close to amps fuse rating without going over ONLY if you have proper electrical. If you don't have enough electrical for 1000 watts then run the 60amp fuse.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
1- XS Power D2700
1- XS Power D3400
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
is your sundown amp fused on the amp? 60 amp fuse seems kinda small for a 1000 watt amp. but i have no experience with sundown so i don't know what current draw it has. might wanna get a larger fuse. just look up specs on it and it should tell you the current draw then use a fuse of the same if not a tad larger amp rating for your batt fuse.
It doesn't have the current draw rating anywhere on their site. I do know the output to my sub is around 30a, and it says it is 86% efficient so lets say maybe at a peak it will output 35a to my sub, and at say 86% efficiency that would mean it's drawing right around 40 amps (35/.86=40.69). I think that's how it works, right? lol I'll see if I can find a 75amp fuse, if not, I'll just get another 60 and see how it goes.
Kicker ZX350.4
Sundown SAZ-1000D
Thank you all for responding and helping! I like CC's suggestion. I'll just go with another 60 amp fuse. I think I should be fine. If not, I'll be back ;)
Kicker ZX350.4
Sundown SAZ-1000D
  • Who's Online   1 Member, 0 Anonymous, 404 Guests (See full list)
