Posted (edited)
Like the title says, can I use what's known as a "current steering" diode (Source: wikipedia "Current Steering") inline before the battery that powers a power inverter? I know most power inverters can induce noise in a system (though I'm unsure how they do it), and that's why I was wondering.
Could I use something like one of these:
http://www.allelectronics.com/make-a-store...-25A-45V/1.html
Or one of these:
http://www.allelectronics.com/make-a-store...TIFIER/-/1.html
Also, could I use more than one diode?
I'm going to be stuck using an inverter for my setup (I already have 3 or 4 laying around, so it'd be cheaper).
Edited by 1992Chevy K1500
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
Posted (edited)
A diode bridge is whats used to convert AC to DC, you need to convert DC to AC.
What are you trying to power on 12v? Audio and computer stuff runs on DC , so all you have to do is bypass the original AC to DC power supply and replace it with a DC to DC power supply.
Edited by Neel
Too Much Stuff to list .
I plan on switching computers a time or 2. So I'd need a DC to DC converter that had a switch (without costing me a lot).
Do you know of any that take 12V in and put out 18.5 volts? It needs to have at least a 3.5 amp output.
Thanks.
15.4" widescreen
What it does:
I would hook it up first before I went into trying to wire diodes inline with it. I've put in alot of power inverters with all sorts of equipment and have got engine noise maybe once from one.
-Installer for Duke's Car Stereo
2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
RF Punch 6.5" components and MB Quart Premium 6x9"s
Powermaster Alternator, YellowTop D34, Vmax CT1000
