All items sold
300 AMP QP alternator with 1.9inch pulley, doesn't really kick on until around 7-800 engine RPM from what I have noticed. Alternator is externally regulated currently.. with an adjustable needle from 14 - 16.1 volts. Can internally regulate it for you if you'd like it to be. I have an MLA module that works with large case CS144's with a two wire configuration. Even at that Chris a helpful guy and I'm sure he'd show you how to rewire it for your application if possible. MLA isn't pictured will have pictures up soon for it once I dig it up.
$250 Shipped on the alternator with normal regulator. 270 with MLA module
additional images were requested for the 4channels.. Here ya go,
AP 30001D
4 Channel APF-1604's
1 APF 1604's,
1.6 inches tall... nice and slim all AP products I've tested do rated power @ 14.4 as long as the voltage is steady...
Specs:
Features:
# ultra slim design for a compact installation
# white light illuminated cooling fan
# white light illuminated terminals
# built-in variable high pass & low pass crossover
# rca line input/output jacks
# electronic protection circuitry to protect the amplifier from short circuit, power overload & thermal overload
# remote sub-woofer volume control
# 41mm(h) x 276mm(w) x 360mm(l)
# 1.6 inches(h) x 10.9 inches(w) x 14.2 inches(l)
# frequency response: 15hz - 30khz
# channel separation: 55db
# total harmonic distortion: <1%
# speaker impedance: 2ohm to 8ohm
# input sensitivity: 0.2v - 6v
# crossover frequency: low: 40-250hz, high: 40-250hz
# bass boost: 0-18db @ 45hz output power (rms) : stereo 2 ch -
# 100w x 4 @ 4ohm stereo 2 ch - 150w x 4 @ 2ohm bridge 1 ch - 300w x 2 @ 4ohm
weight: 12.52 (lbs)
Thank you for looking and don't hesitate to ask any questions!
Remaining 4 channel amp will be 110.00 Shipped
Edited for corrections
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
Will the alternator fit a 96 impala ss. It looks like the mount bolts are in the right spot but I can't really tell. If so How much for it all shipped to 98203
96 IMPALA SS
Pioneer DEH-P8600MP H/U
Pioneer TS-C160R 6.5"
Pioneer TS-D690R 6x9"
JBL GTO755.6II
Stinger spdh-10 cap
100sqft. Fatmat
AQ 3500d
18" FI BTL 7cuft 35Hz
The alternator will fit your vehicle... The plug from my diagram I pulled up in on demand looks like this...
Your Car...
My Car...
cadillac49diagram.pngw
There's a similar 2 wire setup to my car... Only difference is that S on my car is the starter wire... An the F on your car is the starter... The exciter wire that gives the alternator battery voltage when you start the car is the same.
What that means is.. that you may have to get a plug from a cadillac and chop your plug off of your harness and just attach the thicker wire to your thick brown wire and the skinnier one as your turn on. I may have an extra plug for my car for you if you'd like that i can throw in... it's fairly simple to swap them over though. Same 2 wire start up system...
Aside from that, you should be good to go. Your factory harness is what plugs the into the MLA and your MLA plug goes into the alternator. So that part once you get the exciter situation sorted out will be easy.
Total cost to 98203 would be 350 shipped. Alternator , MLA with the plug from my car.
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
do you want $22 for a whole bag of the ring terminals or just a pair???
Custom Car Audio
(815) 916 - 9194
www.midwestsplcustoms.com
2000 Tahoe | 22" GREED Celebrities
Alpine CDA-117
Dual 0/1 Runs
(3) 925 CA Group 31 In Back
(4) 18" FI Audio Q's (W/ Extra Spider)
(4) Hifonics BXi 2010D
Hifonics ZXi 4410
4 RF P1653 6 1/2's
Big 3
All Kicker/Knu Wiring
22.00 per pack... 20 total 10 red 10 black
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
pming about ringterminals
Bills
KwB
Team DC Audio Midwest captain
