Bumpin Taurus Posted November 17, 2009 Report Posted November 17, 2009 So, I was playing my music, take out the CD, put in a new one, and then the subs are hitting, like at all. Pull over, pop the trunk, and they definitely aren't playing. I check the LED on the amp and the power is on, but so is the protect LED. I didn't play a new song or anything, I don't think it was that. Any suggestions? Could it be that it just got too hot? RE SE 12" subs (2) in prefab dual ported box (custom box coming soon) Hifonics bxi610 mono 600 watt amp Stock HU Mach RCU Apline 5 x 7 S Type Speakers (2) (1 blown) Stock rear speakers (2) Pyramid Tweeters (2)
Gotloud555 Posted November 18, 2009 Report Posted November 18, 2009 Have check to see if it will work on 12 volt?
Rydaz1Bass Posted November 18, 2009 Report Posted November 18, 2009 Have check to see if it will work on 12 volt? You might have some wires hooked up wrong or you could possibly have a half way bad fuse who knows it could be the amp thats just bad.lol dont take word from me im just saying but thats what i would check. :search:or you could also be running too thin of a gauged speaker wire...... VehicleCurrentlyOwned:2000Malibu \/MySystem\/ Ken-Wood HeadUnit Cars interior panels Custom blue Done by ME Pheonix Power block running both amps Stinger pro series four gauge wire flex material RimsBrand:Polo Interior lighting Blue neon bars under and around dash Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED) http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg http://www.dcsoundlab.com/images/header.jpg
Bumpin Taurus Posted November 18, 2009 Author Report Posted November 18, 2009 You might have some wires hooked up wrong or you could possibly have a half way bad fuse who knows it could be the amp thats just bad.lol dont take word from me im just saying but thats what i would check. :search:or you could also be running too thin of a gauged speaker wire...... Hm, I seriously think it's just overheated since I've been playing it all day. 4 ga wire and ground wire 12 ga speaker wire Something MIGHT be wired wrong, but it was working on second and the next it's not. RE SE 12" subs (2) in prefab dual ported box (custom box coming soon) Hifonics bxi610 mono 600 watt amp Stock HU Mach RCU Apline 5 x 7 S Type Speakers (2) (1 blown) Stock rear speakers (2) Pyramid Tweeters (2)
Gotloud555 Posted November 18, 2009 Report Posted November 18, 2009 Hm, I seriously think it's just overheated since I've been playing it all day. 4 ga wire and ground wire 12 ga speaker wire Something MIGHT be wired wrong, but it was working on second and the next it's not. What amp are you currently using? YOu should try another different amp and seen if it work. If not then that amp's toast..
Mtgrooves Posted November 18, 2009 Report Posted November 18, 2009 Check the ohm load of you subs and check all connections with a DMM and a little more info would help like...amp model and make and subs model and make as well at impedance. The Shoe Maker without shoes!
Bumpin Taurus Posted November 18, 2009 Author Report Posted November 18, 2009 So, I was playing my music, take out the CD, put in a new one, and then the subs are hitting, like at all.Pull over, pop the trunk, and they definitely aren't playing. I check the LED on the amp and the power is on, but so is the protect LED. I didn't play a new song or anything, I don't think it was that. Any suggestions? Could it be that it just got too hot? OK, this if my first system so you must bare with me. It's a Hifonics Brutus amp(bxi610 I believe) 600 watts They are 2 12" RE SE subs in a ported box I wired them up for one ohm They have been working fine for a few days now. I've played songs with lows and hi's and they were working fine. I think that I DO NOT have the settings right. I have the db over 5(is that bad?) I'm not sure what the volts of my stock headunit are. And I still have to set the gains on the LOC. Also I'm still not sure what the low and hi cutoff/limit should be. Remember I'm new at this. RE SE 12" subs (2) in prefab dual ported box (custom box coming soon) Hifonics bxi610 mono 600 watt amp Stock HU Mach RCU Apline 5 x 7 S Type Speakers (2) (1 blown) Stock rear speakers (2) Pyramid Tweeters (2)
