ok so i have a huge problem which is starting to really bother me. I am having major engine noise problems coming from just my subwoofer. Im running a pioneer head unit with the rca's running down left side of my car and 0 gauge jl wire on right side. from front to the back battery which is a stinger sp1000 battery. The big three is done under the hood and i replaced all my spark plugs and wires under the hood to make sure it wasnt from them.The back battery is grounded with 0 gauge stinger hpm wire to the chassis from the back seat belt buckle with grinded to bare metal. using a buss bar to power the amps which consist of 2 treo rsx1900 amps and one rockford fosgate t-600.2 only the treo amps are hooked up at the moment. the amps turn on fine and work fine and are grounded to the stinger battery but once they turn on i hear major engine noise. also even if i turn the sub control on the headunit the sub still puts out engine noise. i tried running a dry run of rca's and still made the noise.. not sure what to do now please if anyone has any ideas i would like to know. ive heard it could possibly be the pioneer head unit but not sure. any ideas would be helpful.
94' jimmy
stock alt,
big three
stinger sp1000 batt
two treo rsx 1900 monoblocks strapped
rockford fosgate 600.2 for mids and high
focal access components in rear alpine type s front
soundstream highs
treo ssx 12 dual 1 ohm in 3.3 cube foot box
You need to ground you RCAs like this:
It's a common problem with Pioneer HUs.
HU: Pioneer
Highs: 2X 4X6"s, 2X 3.5"s, 4X 5.25" comps, Q-Logic kicks, and a Sundown SAX-125.2
Subs: 4 Nightshade 15s and Strapped SAZ-3500Ds <---Sundown FTW good.gif
Electrical: dual DC Power 320s (ordered) and 2 D3400s up frt and 4 D2700s in the back
.ʇı ɥʇıʍ ʞɔnɟ ʇ,uɐɔ noʎ 'ʞɔıp ǝɹos ɐ ǝʞı1 sı uʍopunS
would this solve the problem. cause my sub was not turning off when the sub control was off. ive gone over every other possible thing i could think
94' jimmy
stock alt,
big three
stinger sp1000 batt
soundstream highs
It will cure your engine noise problem but the sub woofer issue sounds like maybe something isn't set right on the HU. I'd start by doing the ground like in the pic above and see if there are any other problems. I'm pretty sure that will fix all of your problems.
HU: Pioneer
When you say your sub doesn't turn off, do you mean you still hear the engine noise with it off, or do you hear music coming from the sub?
HU: Pioneer
