I downloaded audacity recently, and I figured out how to long songs and all that, but the main reason I got it was to fix clipping. So can anybody tell me exactly howmto fix clipping using audacity. An example for decaf or whoever else would be Nerd by Gucci.
Thanks in advance.
BJ
HU: JVC Arsenal AR880
Subs: (4) Incriminator Audio Warden 15s
Highs: (12)Eminator 8s (12)Eminator 6.5s (12)Eminence Apt80s
Amps: (2) Incriminator Audio 40.1s (subs), (2) MB Quart Discus 4125s, (1) MB Quart 4.80
Electrical:
-DB Electrical 275 amp Ohio Gen
-BIG III
-(5) XS Power d3100s
152.3 In Street Beat 5.
State record in Alabama. (USACI)
http://www.youtube.com/Itgetslow
Idk if thats possible. Now you could lower the volume of the peaks of music to make your amps not clip as soon.
It has a feature in the effects tab that says clip fix
Electrical:
-BIG III
its impossible to fix clipping. clipping can start from anyone editing a song and its only fixed by the studio. no other way.
that clip fix function locks up audacity so its pintless
Guest DC Power Kyle
You can never truly fix a "clip" in the song. It can try to calculate how to fix it but it won't sound anything like a proper recorded version of that song (if the artist actually made one)
Yeah, It locks mine up too. I just thought I was dooing something wrong.
So wat could I do to make it a tad bit safer to play at high volumes?
Electrical:
-BIG III
I use compressor just leave it at the default parameters and click ok
obviously it doesn't fix the clipped signal but it shows in audacity that most of the song isn't clipped any more via the red disappearing.
still not fixed but A TON better than playing it clipped.
when I use the compressor my sub doesn't get as hot compared to the raw clipped song so it does do its job
Wouldnt be thehoe92 without teh purple
you could actually "fix" a clipped song by lowering the gain in the song or audacity has a some program that fixes it for you..i cant remember how but when i get home ill let you know..and "THEHOE92" is correct you could tell when the song is clipped if the screen apears RED.
nope a clipped signal is a clipped signal you have to reshape the whole wave and even then it won't sound like its supposed to but you are right lowering the "gain" of the song is the right way to do it because then when you turn your HU up to normal slamming volume it isn't at the clipped point
Even if you lower the level of the song its still clipped...
I sine wave is suppose to be smooth and round by lowering the "gain" or overall volume of the song the squared off wave just is smaller but still squared off....which will still be a clip and make your woofers see a clipped signal...just not a harsh of one....but it's still a clip nonetheless....
Quit throwing misinformation around....I'm sick of people not knowing what they are talking about telling people to do this...when it could potentially cause them to blow some equipment.
edit: And just because audacity doesn't show those little red bars doesn't mean it not clipped the recording volume might not be high enough to show a clip when one may actually be present.
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
