Benzino Posted November 19, 2009 Report Share Posted November 19, 2009 Doesnt seem like anyone uses a whole lot of screws in boxes that i see anymore.. whats the best screws to use and how far to space them apart? and best sealant to use? thanks Quote Link to comment Share on other sites More sharing options...
Hypnotik DesignZ Posted November 19, 2009 Report Share Posted November 19, 2009 screws are mainly used to hold the wood for the glue to dry 3-4 inches apart is ok from what i heard titebond II woodglue Quote Jensen 9511TS~For Sale JL Audio 300/4~For Sale JL Audio1000/1~For Sale Mephis 6.5 componet sets front and rear 4 15" Fi Q's in a 16 cuft box tuned to 29hrz Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted November 19, 2009 Report Share Posted November 19, 2009 1 5/8" drywall screws is pretty much the standard of what is used by many people... Stay around 4" away from the corners and 3-4" of space between screws. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
rmzsuzuki89 Posted November 19, 2009 Report Share Posted November 19, 2009 (edited) I use course thread drywall screws (length depends on where I'm using them) usually spaced 6-8 inches apart. It all depends on the cut though. If you use a circle saw, and get a pretty straight cut, but not perfect, they may need to be a lil closer to suck the wood down on the glue....^^And I use Titebond II as well, along with silicone on the inside seems. Edited November 19, 2009 by rmzsuzuki89 Quote My Feedback Thread http://www.stevemeadedesigns.com/board/topic/103868-official-rmzsuzuki89-feedback-thread/page__pid__1441542#entry1441542 Link to comment Share on other sites More sharing options...
Benzino Posted November 19, 2009 Author Report Share Posted November 19, 2009 I am about to start building my box i will keep this all in mind when i get that far.. and i see all these boxs people using an extra baffle board.. is this really needed? thanks Quote Link to comment Share on other sites More sharing options...
Big Lo Posted November 19, 2009 Report Share Posted November 19, 2009 I am about to start building my box i will keep this all in mind when i get that far.. and i see all these boxs people using an extra baffle board.. is this really needed? thanks I think this needed depending on how heavy the subs are and how thick the wood is, ex. If youre building a box for 2 18's with .75 MDF, I would highly recommend putting a second or even a third baffle, I'm no professional though, It just releaves stress off the first baffle. Quote Link to comment Share on other sites More sharing options...
tehbert0 Posted November 19, 2009 Report Share Posted November 19, 2009 dont screw too close to the corners. it will split pretty easily Quote http://motorcitydesignsaudio.com Link to comment Share on other sites More sharing options...
Jared420 Posted November 19, 2009 Report Share Posted November 19, 2009 just built my first ported box a week ago and it came out pretty well, I used screws about 4 inches away from eachother and at least 2-3'' from corners. LOTS of titebond 2 glue and i may have gone a little overboard on the sealing but I put a bead of liquid nails on the inside and outside of every seam and smoothed it over with a finger and then a few days later I went back over every inside seam with some silicone so I have some nice rounded corners that should be just about as airtight as you can get. Quote 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts Link to comment Share on other sites More sharing options...
kanarrjl Posted November 19, 2009 Report Share Posted November 19, 2009 (edited) i predrill my screw holes so they don't crack the mdf i use these they work great and countersink Edited November 19, 2009 by kanarrjl Quote 97 Honda Civic Sedan Rear disc brake conversion 2" drop 17's lots of exterior mods SYSTEM SoundStream VIR-5850 Dvd player RE 6x9's and 6.5's Soundstream DTR4.500 Soundstream DTR1.2200 8" RE-x in a t-line Kinetik 1800 Plans 4-SA-8's Another Kinetik High output alt My Cardomain Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted November 20, 2009 Report Share Posted November 20, 2009 I am about to start building my box i will keep this all in mind when i get that far.. and i see all these boxs people using an extra baffle board.. is this really needed? thanks Is very dependant on what woofers and amps you'll be running... So what are u running?? Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
