Cherokee's Bass Posted December 2, 2009 Report Posted December 2, 2009 instead if ordering anything you could always go get some aluminum 1.1/2" wide by 1/4" and around 4-6" long depending on how much you need and just drill out 2 holes at the top so you can bold it to your excisting terminal and then drill however many holes you need for your wire and bolt that to it and your done homemade bussbarkinda like this Im liking that alot! 2010 Spring Build 3 18'' FI BTL'S Sub's 3 New AQ 3500.1D Amp's 8 Run's of 2/0 Welding Cable 2 Dc Power 270Xp Alt's 6 HC2400 & 1 HC800 Battary Second Skin Audio And much more...
Marlo Stanfield Posted December 2, 2009 Report Posted December 2, 2009 instead if ordering anything you could always go get some aluminum 1.1/2" wide by 1/4" and around 4-6" long depending on how much you need and just drill out 2 holes at the top so you can bold it to your excisting terminal and then drill however many holes you need for your wire and bolt that to it and your done homemade bussbarkinda like this This is exactly what i have under hood right now.. Made sum out of the leftover copper i had from my buss bars. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Blue_C1500 Posted December 2, 2009 Report Posted December 2, 2009 instead if ordering anything you could always go get some aluminum 1.1/2" wide by 1/4" and around 4-6" long depending on how much you need and just drill out 2 holes at the top so you can bold it to your excisting terminal and then drill however many holes you need for your wire and bolt that to it and your done homemade bussbarkinda like this Holy.... No AC? WTF How do you do it? Anyway back on topic. This does look good. How much current are you drawing through that setup? HU: Pioneer Highs: 2X 4X6"s, 2X 3.5"s, 4X 5.25" comps, Q-Logic kicks, and a Sundown SAX-125.2 Subs: 4 Nightshade 15s and Strapped SAZ-3500Ds <---Sundown FTW Electrical: dual DC Power 320s (ordered) and 2 D3400s up frt and 4 D2700s in the back .ʇı ɥʇıʍ ʞɔnɟ ʇ,uɐɔ noʎ 'ʞɔıp ǝɹos ɐ ǝʞı1 sı uʍopunS
jl10w3s Posted December 2, 2009 Report Posted December 2, 2009 I thin the picture tell you the story!any suggestion on how to make less messy? $30 -monster slimline terminal: (2001 Dodge Durango R/T) 1- XS Power D2700 1-Alpine CDE-HD149BT (Head Unit) 1 pr.- Focal Polyglass 165v30 (Front Stage) 1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill) 1-Kenwood Excelon XR-1S (Sub Amp) 1-Kenwood Excelon XR-4S (Mids-N-Highs Amp) 2- JL 10 W3v3-4 (Subs) -2.3 Cubes tuned to 32 hz 1-1/0 ga. & Big III in 1/0 140 @45 hz db drag legal (2008 Toyota Highlander Limited ---build in the works) 1- Kenwood DDX470 (Head Unit) 1 pr.- JL C3-650 (Front Stage) 1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead) 1- JL XD-400/4 (Mids-N-Highs Amp) 1- JL XD-600/1 (Sub Amp) 1- XS Power D3400 1- JL 10w3v3-2 (Sub) 1- JL 2 Ga. Amp Kit 1- BIG 3 in 1/0 1- self-built Fiberglass sub enclosure
