I know that it wont solve the problem for sure, but its better than buying 2 $75 sensors, i've done it plenty of times for customers and it worked fine
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
  • 5 weeks later...
Try this. DLC listed as under dash center of vehicle.
FLASHING DIAGNOSTIC TROUBLE CODES (DTC) WITH THE 12 PIN DLC CONNECTOR (PIN "B" INCLUDED)
A diagnostic scan tool must be used to read diagnostic trouble codes unless the vehicle has a 12 pin DLC connector equipped with a DLC connector terminal "B". The DLC connector terminal "B" (if equipped) is the second terminal from the right of the DLC connector's top row. The terminal is grounded by connecting terminal "B" to terminal "A" (internal PCM ground). Both terminals are located to the right side, and on the top row of the DLC connector.
Once terminals "A" and "B" have been connected, the ignition switch must be moved to the "ON" position, with the engine not running. At this point, the MIL should flash DTC 12 three times consecutively. This would be the following flash sequence: "flash, pause, flash-flash, long pause, flash, pause, flash-flash, long pause, flash, pause, flash-flash." DTC 12 indicates that the diagnostic system is operating. If DTC 12 is not indicated, a problem is present within the diagnostic system itself, and should be referred to the appropriate diagnostic chart.
Following the output of DTC 12, the MIL will indicate a DTC three times if a DTC is present, or it will continue to output DTC 12. If more than one DTC has been stored in memory, the DTCs will be output from the lowest to the highest, with each DTC being displayed three times.
Edited by toytrkdrvr
