bigchevyrider Posted November 24, 2009 Report Posted November 24, 2009 I had 3 15'' L5s in a walled off maxima, I just bought a chevy silverado and wanna start fresh, i know im getting 2 L7 15''s. My amp isnt mono block and is stable at a 4ohm load, should i buy dual 2ohm voice coil or dual 4ohm voice coil and how should i wire it to slam? Help pleasee!!
Marlo Stanfield Posted November 24, 2009 Report Posted November 24, 2009 Dual 4s... Here ya go - http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=4 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
ISO Posted November 24, 2009 Report Posted November 24, 2009 Dual 4 but I'm curious about what amp you have and how much power you will have. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
Marlo Stanfield Posted November 24, 2009 Report Posted November 24, 2009 Dual 4 but I'm curious about what amp you have and how much power you will have. x2 on what amp the OP has... Sounds like a 2 channel that does power bridged @ 4ohms though. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
ISO Posted November 24, 2009 Report Posted November 24, 2009 x2 on what amp the OP has... Sounds like a 2 channel that does power bridged @ 4ohms though. I'm just thinking that if its a 2 channel Class A/B amp than it might not make more than 1,000 watts bridged (I know a few companies came out with bigger amps) and is current hungry and in my opinion is not enough power to run the L7 15s properly unless they are in a ported box. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
splzx3 Posted November 24, 2009 Report Posted November 24, 2009 dont u have a other topic about this? ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
