I seen these speakers for sale for only $5 a pop and i couldnt resist. I dont even really need them but then i was thinking hey why not make like 2 towers in my room and call it a day and see how they sound. If i dont like ill just sell them. Well i got 16 of them
lmao 5 1/2 speaker
Woven fiberglass cone, soft plastic dust cap, rubber half roll surround, plastic chassis. 1" voice coil with 7/16" winding on an aluminum former. Extended polepiece lowers distortion and increases Xmax. Magnetically shielded. Buyout, limited quantities. Specifications: *Power handling: 40 watts RMS/80 watts max *VCdia: 1" *Le: 0.87 mH *Impedance: 8 ohms *Re: 6.1 ohms *Frequency response: 40-3,500 Hz *Fs: 71 Hz *SPL: 86 dB 1W/1m *Vas: 0.22 cu. ft. *Qms: 3.67 *Qes: 0.86 *Qts: 0.68 *Xmax: 3 mm *Dimensions: A: 5-3/4", B: 4-5//8", C: 3".
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
At least your lil addiction wasn't very pricey... Hell when my old shop closed down I bought up over $4k worth of equipment from my old boss/owner of the shop. The actual equipment itself I could have resold it all for prolli 3x what I paid for it. I sold enough of the amps/subs/wiring that I made back the money I spent and ended up with 5 or 6 amps still and right around 10-12 woofers.
Pioneer AVIC-N2
where did you get those speakers from?
partsexpress.com
stock is limited so hurry fast, they go fast man.
look uner the sale section on the left tab on the site, you will find them there
1 3500d AQ amp
LOL I have that problem with amps.
I still seem to average 15 amps at any given time and I only own a single cab truck.LOL
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
