Vehicle is a 2002 Mazda Protege ES with the 2.0L. (Stock alt)
Alt went out a few days ago, had it rebuilt at a local shop and again its not working. Headlights were dim as hell, Pioneer deck wouldnt turn on etc...
What could cause this?
It has a shitty Dual 550W max amp in it..
Edit: Sorry if in wrong section
Edit2: All these problems started after new Pioneer deck was installed.
Edited by solo_x18
Derp.
Try a different deck, or a HO alt.
Just because it was "rebuilt" doesnt mean the proper parts where used.
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
There will be no need for a H.O. alt. That lil Dual amp is the most thats going in there.
I just wanna know whats causing it, not how to upgrade. What could the Pioneer deck be doing to the alt/electrical system? It plays and works flawlessly just shuts off along with everything else when voltage dips. Tried diff batts already.
Derp.
I really dont know, but the only reason I suggested it was to start the process of elimination
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
Could the problem be a loose/slipping/worn alt. belt?
Its a 4 rib belt and the 2 outer ribs are gone, and the belt is pretty slick.
Derp.
Guest DC Power Kyle
Yeah if 2 ribs are gone and if it's really slick I would recommend a new belt. You may want to look into a new pulley if it's glazed as well
New pulley? How would I tell if its glazed?
We just put a new belt on and it seems to take the load from the blower/lights. Hopefully this resolves the problem.
Derp.
Guest DC Power Kyle
If the belt helped that much then you probably don't need a pulley.
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
