Torres Posted November 29, 2009 Report Posted November 29, 2009 first thing i'd do is turn that bass boost down. all the way. then readjust your gain properly. for displacement, depending on size of the box and number of subs, i usually use around .2 ish for each sub, then add a few tenths for bracing displacement. the bigger the box is you build, the more surface area of port you'll need to properly suit the enclosure. general rule of thumb is 12-16 sq inches of port per cubic foot. frequency tuning depends on how much port area you have. less area will require a shorter port length than that of one with more port area in the same box to maintain the same tuning. are you going to be using an aero port? that quote says one 4" port for a 2 cubic foot box. doing a 4 cubic foot box going by those recommendations you'd need two 4" ports. each 10 3/4" long. i havent checked that tuning so i'm assuming it's right. if you're fully lost, post the dimensions you have to work with and someone can help you with a design Quote
ATLien Posted November 30, 2009 Author Report Posted November 30, 2009 Here's where I'm at so far on the design. I'm going to go with subs up, slot port facing back. I have plenty of room in height and length on the truck. No worries there. The width is right at about 46 inches so 44" would be nice and snug. Quote
Steph3n1 Posted November 30, 2009 Report Posted November 30, 2009 yo i live pretty close to atlanta i could prolly help you out with gettin this done right Quote 2005 Ford Ranger Reg cab Build in Progress T3 Audio T2000 12 ARC SE4000 Stinger HPM 1/0 Wire DC power 270xp Batts: 1 Redtop up front and a Stinger SPP2250 in the back Hopes to be in and around a 150....weel see my youtube channel http://www.youtube.com/user/steph3n1 Team DBs (Driven By sound)
kleanNOMA Posted December 1, 2009 Report Posted December 1, 2009 u can put um at 1 oHM if ur amp can handle it Quote yellow optima kicker 0gauge Alpine CDA-105 4 infinity 6 1/2s - 2 infinity 6x9s Audio Control Epicenter 1 Hifonics XX Hurcules 8K hid 2 RF HX2 18s D4 sealed at 8cubes 4 now in a grand cherokee box build comin soon
kleanNOMA Posted December 1, 2009 Report Posted December 1, 2009 sory bout that go to 2 ohms And X2 on lowering ur BB Quote yellow optima kicker 0gauge Alpine CDA-105 4 infinity 6 1/2s - 2 infinity 6x9s Audio Control Epicenter 1 Hifonics XX Hurcules 8K hid 2 RF HX2 18s D4 sealed at 8cubes 4 now in a grand cherokee box build comin soon
Tooshort064 Posted December 1, 2009 Report Posted December 1, 2009 (edited) I have the punch series.Here are the specs for the subs. I'll be using two of these. # dual 4-ohm voice coils # CONsealer gasket hides mounting screws and prevents air leaks around the frame # frequency response 26-200 Hz # power range 150-500 watts RMS (250 watts per voice coil) # peak power 1,000 watts # sensitivity 88 dB SPL # top mount depth 5-13/16" # sealed box volume 0.8-4.0 cubic feet # ported box volume 1.75-4.0 cubic feet Here are the specs for the amp. # Max power 2-ohm 1000W x 2, RMS power 4-ohm 300W x 2 # Max bridged power 4-ohm x 2000W x 1, signal-to-noise ratio > 102dB, THD 0.01% # Features remote subwoofer level control, tri-mode operation and bridgeable # 11 7/8" W x 2 5/8" H x 16 13"/16" L Right now I have the subs wired up at 4 ohms bridged according to Rockford's diagram. You think I should drop down to 2 ohms or leave it at 4? first off that amp will not handle a 1 ohm load . your subs can either be wired @ 1ohm or 4ohm and that amp will go into to protect if you even do a 1ohm load. and why ur subs are going into shit mode is a totally different story. like build quality of the amp . you probably have the gain turned up. way up and and when you give it volume its sending a "2000 Watt" clipped signal and tearing your subs apart. get a better amp before you kill those woofers. Edited December 1, 2009 by Tooshort064 Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
