that is teh question....
ok im running my amp at 2 ohm now but i can switch my subs to dual 4 ohm to run my amp at 1 ohm to do so i am doing the below (with the batts)
ok im getting my yellowtop installed and i got my kinetic cap bat on order now. i think i may switch to some T2s. would 1400 RMS for 2 t2s sound good. so thats 700 RMS between 2 T2 12s. lemme see some votes either:
A. Stick with T1s and run them at full RMS power
or
B. Upgrade to T2s and run them at 700 RMS a piece.
vote and your thoughts....
NoFearX18 said:
trainman0978 said:
t1's put your money towards power upgrades and play with your subs a while. When I was starting out (don't know how long you've been installing) I had one spl160 (soundstream oversized 15" from ten yrs ago) and built 5 different (no exageration) for it and learned alot about making a sub sound good. Have fun and after alot of experimenting  upgrade. I know it helped me learn alot about what works and what doesn't. just my .02
My opinion, and it's only my opinion....Give the T2's atleast 1k RMS each. I've seen them take 1400-1500 fine, but never seen them take anymore than that. Wonderful subs though. I was considering them @ one time.
i guess ill just stick with the T1s and run them at full RMS power
NoFearX18 said:
trainman0978 said:
if i wanted to upgrade to T2s i can swap my 2 T1s for 2 T2s for around 250-300 dollars....should i do it??? answers now YES OR NO
NoFearX18 said:
trainman0978 said:
Bigger is  not always better I say if you plan on upgradeing the amps too then youcould get the t2's for awile and then upgrade the amps.. IMO
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
i switched out my T1 and dropped in the T2s, although they are only getting 750rms a piece i plan on getting a bigger amp if not adding another one. get the T2s if you plan on upgrading your amp later.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
