T2 or not to T2
that is teh question....
ok im running my amp at 2 ohm now but i can switch my subs to dual 4 ohm to run my amp at 1 ohm to do so i am doing the below (with the batts)
ok im getting my yellowtop installed and i got my kinetic cap bat on order now. i think i may switch to some T2s. would 1400 RMS for 2 t2s sound good. so thats 700 RMS between 2 T2 12s. lemme see some votes either:
A. Stick with T1s and run them at full RMS power
or
B. Upgrade to T2s and run them at 700 RMS a piece.
vote and your thoughts....
NoFearX18 said:
trainman0978 said:
t1's put your money towards power upgrades and play with your subs a while. When I was starting out (don't know how long you've been installing) I had one spl160 (soundstream oversized 15" from ten yrs ago) and built 5 different (no exageration) for it and learned alot about making a sub sound good. Have fun and after alot of experimenting  upgrade. I know it helped me learn alot about what works and what doesn't. just my .02
i guess ill just stick with the T1s and run them at full RMS power
NoFearX18 said:
trainman0978 said:
if i wanted to upgrade to T2s i can swap my 2 T1s for 2 T2s for around 250-300 dollars....should i do it??? answers now YES OR NO
NoFearX18 said:
trainman0978 said:
Bigger is  not always better I say if you plan on upgradeing the amps too then youcould get the t2's for awile and then upgrade the amps.. IMO
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
i switched out my T1 and dropped in the T2s, although they are only getting 750rms a piece i plan on getting a bigger amp if not adding another one. get the T2s if you plan on upgrading your amp later.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
