Speakers-
(2) Pioneer speakers. 260 peak. 50 RMS.
(2) Kenwood speakers. 200 Peak. 40 RMS.
(1) 12" Audiobahn SE (special edition)
Headunit-
Pioneer DEH-7500mp (not sure about the model number but it looks exactly alike.)
Amp-
Crunch http://www.onlinecarstereo.com/CarAudio/p_...h_BMX_4100.aspx
The headunit does not seem to output sounds to the speakers when hooked up to a wire harness. There is a DUAL head unit in the car as of now that works and when I took that off, I plugged the pioneer up to the wire harness the same way the DUAL came off and no output. I could hear the stereo beep while pressing buttons, but nothing came from the speakers. What can this be? Would it possibly output sound if I hook it up to the amp with RCA connections, then run the amp to the speakers?
I don't know what to do really. I want to hook up the speakers most of all and the sub if I can. The amp is only 4 channels and that will be going to the 4 speakers so no sub. I don't think the speakers can handle the power but idk... The amp does 4 ohms each channel with 100 watts per channel which is the lowest power I think.
Or should I just hook up the amp to the sub? The amp will do 2 channels of 300 watts per channel. The sub is rated at 400RMS and 800peak (approx) I think the sub may be underpowered. :\
What do I do!!!!??? I just want to hook something up for my first time. :P
Put on of each speaker on the frony two channel
bridge the back two on the sub.
like this
Channel 1 1pioneer and 1 kenwood
Channel 2 1pioneer and 1 kenwood
Channel 3 Positive on sub
Channel 4 Negative on sub
as good as you are gonna get with what ya got. put that sub in a really decent box and it shouldnt sound too bad
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
like this
Thank you very much for the reply. I appreciate it!
The sub is already in a box from the audio shop they put it in. :)
Any suggestions on a wiring kit? What all would I need to hook it up? I see they have "caps" and some sort of terminal for the positive. But I think those are not necessary. However I do know I need a FUSE at least 12 inches from the positive battery terminal, right? :) And I think that is all? Wiring kit, speaker wire, and a fuse.
What gauge wire should I look for the amp positive, negative, and speaker wires?
EDIT: also, I know nothing about the box or what it's tuned at. I am thinking on making my own ported box for it though. I see 32hz is very popular. Can I do that? :D
Edited by JayP
http://www.sonicelectronix.com/item_13218_...allBay+AK4.html
not the best wiring kit in the world, but it should work for your application
As far as a box goes, depends on what you listen to.
If you want to be pretty loud on rap and hip hop, tune around 35-36hz
If you want a flatter response and a little more rumble, tune 30-32hz
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
Thanks.
um, I listen to stuff like kid cudi, asher roth, LMFAO, and Eminem. Bass lines that are fast and punchy pretty much. :)
i have that wire and i hate it. its barely bigger than the monster 8 gauge i got ripped off of a few years ago.
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4 some legit wire right here but sadly its out of stock
