What all will be needed?
Ok im doing my first major setup from the ground up. First time im running multiple batteries amps etc so I need a little bit of help of what all to order. What battery terminals will I need? Fuse blocks etc? I am running 2 optimas in the back and 1 under the hood. Running a ia 40.1 and a dat 4125. Any other information you need please just ask and I will let you know what I am running. Trying to keep everything under $200.
Lincoln LS build
Dat 4125
IA 40.1
2 CD omega 12s
4 AA carbon fiber 7in mids
3 optima yellow tops
Damplifier pro everywhere
I will also be using a dc 270 alt and the new xs vcm. I think with the alt I will have enough. Trying to find out more or less what I will need material wise.
Lincoln LS build
Dat 4125
IA 40.1
2 CD omega 12s
IMO you need more battery. Unless those Optimas are G31s. The 40.1 will pull a lotta juice.
x2 on more batts, the 40.1s will make a ton of power but are sum current whores. No reason to risk running into problems with an amp like that.
Pioneer AVIC-N2
Ok ill get another battery. Can someone please answer my questions now
Lincoln LS build
Dat 4125
IA 40.1
2 CD omega 12s
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
